Old 03-16-2008   #1
Default Someone was hammered when they put the intake on!
Or at least that has to be the reason the damn gaskets are so far misaligned!
Check this out, 32 mm at some points due to misaligned gaskets.
Gasket shows it best, look at the overlap:
http://i134.photobucket.com/albums/q...f/DSC02422.jpg
http://i134.photobucket.com/albums/q...f/DSC02421.jpg
Now I know why someone also put a 64MM TB on a 60MM plenum
92 ZR1
#234
Old 03-16-2008   #2
Default Re: Someone was hammered when they put the intake on!
Lee,
Who's gaskets?
Old 03-16-2008   #3
Only marking is a what looks like a small thermostat housing gasket, with I believe RGW in the center.....tiny stamp. Is got a grey gasket material around the oil and water passages, looks like some ROLs, I have had before on my old L98.
You are probably right, bolt holes are in good shape, probably a crappy gasket.....I don't know why you would leave this on if lined up so bad!
91 ZR1
#234
Old 03-16-2008   #4
May not be a bad gasket at all. I've seen significant core shift in several Injector housings and plenums, all different from one another. I have discussed it with Aaron Scott before and he went so far as to say it's not uncommon and not difficult to deal with when porting.
Old 03-16-2008   #5
Zr1 Destroyer
Zr1 Destroyer's Avatar
That stinks...looks like somebody was in a hurry and not double checking their work...bummer!
Zr1 Destroyer is offline   Reply With Quote
Old 03-16-2008   #6
91 ZR1
#234
The ones we pulled off my motor today had the gray sealant around the oil and water passages.
Old 03-16-2008   #7
These gaskets are black vs the tan color of yours.
92 ZR1
#234
Old 03-16-2008   #8
bradslt5
black gaskets might be factory . if they have a blue ring (printoseal))thay for eure factory . tan one probably white racing
