Old 02-22-2008   #1
32valvZ
32valvZ's Avatar
Default what spark plugs are you guys using?
are the NGK BKR5EIX the plugs of choice on a stock engine?
Old 02-22-2008   #2
Jeffvette
Default Re: what spark plugs are you guys using?
Yep, I run the iridium plugs on my car and customer cars. Plug # 6341 for your car.
Old 02-22-2008   #3
Aurora40
Aurora40's Avatar
I believe I'm using the BKR7EIX. Keep in mind the '90-92 plugs have a different seat than the '93-95 plugs when comparing part numbers.
Old 02-22-2008   #4
Polo-1
NGK # R5671A-10 for the 125 shot.
Old 02-22-2008   #5
flyin ryan
flyin ryan's Avatar
with that cold of a plug you could run a 400 sniff without worry you'll lose a plug. wow that's cold
Old 02-22-2008   #6
flyin ryan
flyin ryan's Avatar
Jeff's 100%. 90-92's NGK stock no: 6341=BKR5EIX. on 93-95 NGK stock no: 7164=TR55IX. these would be more for stock or close to stock applications. on 90-92's in a pinch you could use NGK FR5's too.
Old 02-22-2008   #7
Jeffvette
Why are you running them when you haven't sprayed yet..... Has the bottle even been filled yet ?
Old 02-23-2008   #8
Polo-1
OOPPS
NGK #FR5's for the 125 shot and 10's for the 150 pill.
Just what others are running.
From the NGK web the 10's are only 2 sets colder. Plug are not fouled, must be ok to run. I dont need a hot plug for smog.
Old 02-23-2008   #9
Noobie Q.
Does it really make a difference which plug in a stock LT5? I use the ac delco replacement for the FR2LS plugs that came in my 90.
TIA
Old 02-23-2008   #10
32valvZ
32valvZ's Avatar
Ok, cool. I already spent the $70. on them!! Gapping at .050...correct?
