Old 02-20-2008   #1
91vettezr1
91vettezr1's Avatar
Default MISC ZR1 PART 4 SALE
Hi
I have some parts that I need to sell ,here is a list. I have pictures of all of these items. Shipping is extra. all parts below are new/n.o.s. unless noted. Will do trade for (2) 94-95 zr1 17"x9.5 wheels must be near mint.
thanks
TODD 91 zr-1 #765 turq/black.
1990-95 Corvette ZR1 LT5 Chromed bolts These are all original GM hardware that was triple chrome plated. I use to have this on my car but have decided to get NCRS judging down the road so this has to go. I have the following : (46) chromed cam cover bolts ,(2) black cam cover bolts. 48 is needed but 4 bolts you don't even see when installed. (8) Coolant outlet pipe bolts, (12) plenum bolts, (3) smaller cam cover bolts. (2)clips and (2) screws for accelerator cables(this is for 90-92 lt-5's, 93-95 use a similiar clip but only for 1 cable) $220.00 for all.
(2) original gm cam cover emblems ,triple chrome and hand painted. These have new tape on the back ,so you just peel and stick. $85.00 SOLD!!!!!!!!!
COMPLETE SET OF MINT CCW Classic 18" 3-piece rims with upgraded ARP stainless bolts. with michelin pilot sports 1500 miles on wheels & tires. $3000.00 SOLD!!!!!!
1990-95 Corvette ZR-1 ZR-1 Bosch new 02/OXYGEN SENSOR has stripped threadsbut can be repaired. $15
1990-95 Corvette ZR-1 ZR-1 SECONDARY PORT THROTTLE VALVE gm part # 1997222 $50
1993-95 Corvette ZR-1 OIL PUMP , GM part # 10187763 $175
1990-92 Corvette ZR-1 POSITIVE BATTERY CABLE , GM part # 12073841 $100
1990-95 Corvette ZR-1 LT5 OIL COOLER LINES, GM part # 10226142. these are the original lines from the factory,not the newer updated lines $225 SOLD!!!!!!!!!
1990-95 Corvette ZR1 LT5 UNDER BODY PASS/DRIVER SIDE NEAR MANIFOLDS heat shields used $50
1990 CORVETTE ZR-1 LT5 OIL PAN WITH WINDAGE TRAY. Brand new N.O.S. GM part # 10122165 $260
1990-92 Corvette ZR1 LT5 Manifold heat shields . USED , EXCELLENT CONDITION, 3 shields included inner & outer shields for the drivers side outer for the passenger ,no inner shield $55
1993 Corvette Center Caps, used but in excellent condition.GM part # 10137865 $60
N.O.S. GM REAR BRAKE HOSES, gm part # 10097649 & 10097659 left/right.$50
(4)Custom Bilet Aluminum Center Caps, engraved with the zr-1 logo.$150 SOLD!!!!!!!!
1990-95 used dipstick $35.00 SOLD!!!!!!!!!!!
tommy morrison poster/lt5 eds $20 mint.
90-95 zr1/lt5 wires replacement ,new in the box sealed. these are not the wires with the "corvette lt5 logo" $50.00 !!!!!!!!!!!!!!!shipping is extra!!!!!!!!!!!!!
91vettezr1 is offline   Reply With Quote
Old 02-20-2008   #2
RHanselman
RHanselman's Avatar
Default Re: MISC ZR1 PART 4 SALE
I will take the CAM cover emblems. Ill be back in town this weekend and can paypal you then.
Thanks,
RH
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
