Old 02-19-2008   #1
HADI-ZR1
Default Which Battery Do you use ??
Which battery do you use for Zr1 ?
1-AC Delco.
2- Oddessy
2- Optima
3- Diehard
4- Motorcraft
5- other brand.
Please Z factor make the poll for the thread. thanks.
today I bought SKUD ,55Ah. ! well, at this time.
empty weigh 6.7 kg !
L = 9.25 "
W= 6.50 "
H = 7.50
- this is about similer size as opitma red (RT U3.7) with 44Ah. and weight = 15kg!!
Old 02-19-2008   #2
bradslt5
Default Re: Which Battery Do you use ??
Ok, i should know better than to answer truefully, but i will, A motorcraft. believe it or not i have had great luck with them. allthough i have to polish that one panel alittle more as it seems to get a rash
Old 02-19-2008   #3
Z Factor
Z Factor's Avatar
Lightbulb Re: Which Battery Do you use ??
There is already a poll.
http://www.zr1netregistry.com/forum/...ead.php?t=1351
Old 02-19-2008   #4
HADI-ZR1
Originally Posted by Z Factor
this is what happen when you spend more time in Corvette babes section.
Oddessy and motorcraft not there in the poll .
Old 02-19-2008   #5
Z Factor
Z Factor's Avatar
Well Motorcraft is Ford, so I would be surprised if any Corvette owner would defile his ZR-1 that way.
As to the Odyssey, last time I checked (several years ago) they did not make a ZR-1 specific battery. The one they said "might" fit had both side and top posts. Also as I recall it was more than $250.00 for a battery that "might" be ok.
So if anyone actually has an Odyssey in their ZR-1, I will add it. And if someone is brave enough to admit putting in a Motorcraft, I will add it to the list. Of course their ZR-1 card must immediately be confiscated and the authorities notified for possible criminal prosecution.
Old 02-19-2008   #6
Locobob
I have an Odyssey 925 in my Z. Been using it for about 2 years now without a single problem. Kind of spendy at around $160 but it only weighs 26lbs - good weight savings for the dollar if you ask me.
Robert
Old 02-19-2008   #7
HADI-ZR1
This is the one i wanted to buy,same as you. but US postal refuse to ship the battery to KUWAIT , the only shipper would do is Fedxpress and it was so expensive!! so i cancel my order.
Good choice man.
Q: is the 380 CCA will be fine for Z ?
Old 02-20-2008   #8
Z Factor
Z Factor's Avatar
You prompted my curiosity so I contacted a vendor I bought my motorcycle battery from. He said the PC925's dimensions are H 5.04, W 7.05, L 6.64 and weight is 24lbs. If yours is 26lbs, then you probably have a PC925MJT with a metal jacket which has extra heat and vibration protection. The 380cca of the PC925 is not what Odyssey likes to go by since they claim to have more accurate ratings compared with other battery manufactures. So they say the 925 has in fact 925ca for 5 seconds at 32 degrees (cca is suppose to be a 30 second start at 0 degrees). Supposedly, the battery they recommend for ZR-1's is the PC 1230 which has 710cca, or 1230ca for 5 seconds at 32 degrees. Confused yet?
They claim that some battery companies don't measure with the same parameters, so the numbers are inflated. There is no mandatory requirement for them to use the 30 second crank at 0 degrees to achieve an actual cca number.
Regardless, since you have one in your ZR-1, I added it to the poll.
Old 02-20-2008   #9
Nick
Nuttin' but the best for my ZR-1...Kirkland Signature Brand by Costco! Anything else is a waste of money.
Old 02-20-2008   #10
carter200
carter200's Avatar
Duralast Gold
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
