Old 02-11-2008   #1
Lowflight
Lowflight's Avatar
Default If I get the Samco Hoses, Does it Replace ALL Hoses AND Does It Include New Clamps?
I found my collant leak and want to replace ALL hoses and get new clamps and everything. The ZR-1 store is kinda vague about the clamps (nothing)
Lowflight is offline   Reply With Quote
Old 02-11-2008   #2
Lowflight
Lowflight's Avatar
Default Re: If I get the Samco Hoses, Does it Replace ALL Hoses AND Does It Include New Clamp
Also, how do I find out if they have BLACK in stock NOW? I can't wait 6-8 weeks.
Old 02-11-2008   #3
bobbyhi
bobbyhi's Avatar
Default Re: If I get the Samco Hoses, Does it Replace ALL Hoses AND Does It Include New Clamps?
Go to the NetRegistry store and you can puchase them now (if in stock) and the clamps are extra. 6 hoses are included which is all you need..
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 02-11-2008   #4
Lowflight
Lowflight's Avatar
Thanks, but where do I get the clamps?
Old 02-11-2008   #5
Lowflight
Lowflight's Avatar
Nevermind, my computer was cutting off the bottom part that had the CLAMPS..found em
Old 02-11-2008   #6
phrogs
phrogs's Avatar
I dont think that you "need" the clamps but it cant hurt I guess
JOHNNY P
Currently own
Old 02-11-2008   #7
Lowflight
Lowflight's Avatar
Does anyone know who I can contact to see if the hoses I ordered are in stock or have to be ordered. I can't afford to wait 8 weeks
Old 02-11-2008   #8
HADI-ZR1
I am going to produce Carbon Fiber duct including the open Air filter frame ( it will be One piece) , working better and good looking too !
i will making them just for who want it !
But its up to you Pal! .
OR you can just replace hoses with Samco, and leave the Duct to be Carbon fiber.
BTW, I was one of those folks who wanted to Fix Samco, But i Cancel it ,cuz
i know Carbon fiber going to be the best choice!
Old 02-11-2008   #9
Actually, there are 2 more short hoses that should be given attention also. they are on the tube on the pass side of the plenum and supply coolant for the plenum @ the throttle body.
Personal experience: I had one split, on the inboard side and blew at least a gallon under the plenum. More went in than could drain out. Starter shorted from 12V stud to block. Amazingly, it sat for an hour or so while I was replacing the hose and started right up with push-start. Drove home, sat for a few days before it ever quit dripping coolant from the valley drain. Starter worked, but I didn't want all that moisture there so pulled plenum, replaced starter (arc blew hole in 12V stud insulator) cleaned coil pak base & all wiring connectors & silicon lubed everything. Never a problem.
Moral of the story is.... don't forget those 2, small hoses. They get old too!
Wish someone would get a stick or 2 of the right size Samco hose. I would sure buy a piece.
Old 02-11-2008   #10
Aurora40
Aurora40's Avatar
FYI, it is not "all" hoses. It's all the clamped coolant ones. But there are still small hoses from the side of the plenum, the crimped ones off the remote pressurized reservior, heater core lines, etc that aren't included.
Bob Saveland
Former owner of #2517
