Old 02-08-2008   #1
Default 63mm TB
I am moving forward on porting the plenum and IHs. I also have a 63mm TB. Haven't checked yet but is it necessary to port the TB openings on the plenum to match the 63mm TB or are they large enough already?
Old 02-08-2008   #2
lbszr
lbszr's Avatar
Default Re: 63mm TB
The plenum port on mine was 1/16 inch or so smaller than the 63mm, so it got match ported to the tb. gasket doesn't match either.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 02-08-2008   #3
Default Re: 63mm TB
Thanks!
LGaff,
I know you have a 63mm on yours. Can you tell if it is port matched or left alone? Is the port opening smaller than the TB?
Old 02-08-2008   #4
lbszr
lbszr's Avatar
Default Re: 63mm TB
I matched the ports to the TB and also the air horn needs opened up to match also.
Old 02-08-2008   #5
kenthompson
kenthompson's Avatar
Default Re: 63mm TB
Man, I'm looking at the plenum and those secondary holes are HUGE! What is the difference going to 63MM?
1990 Grey/Black
Too many for the sig.
kenthompson is offline   Reply With Quote
Old 02-09-2008   #6
phrogs
phrogs's Avatar
Default Re: 63mm TB
It should be port matched on the plenum to the throttle body I mean whats the point if you dont port match them together?
JOHNNY P
Currently own
Old 02-09-2008   #7
Aurora40
Aurora40's Avatar
Default Re: 63mm TB
If you mean specifics, I believe stock is ~58mm secondary ports. So the difference is 5mm in diameter. If you mean what is the power difference, I don't know.
As an aside, two 63mm TB's and the single 23mm would have the same area as a 92mm single TB.
Bob Saveland
Former owner of #2517
Old 02-09-2008   #8
Locobob
Default Re: 63mm TB
The stock plenum throttle bores are 59.5mm in diameter. You should open them up to 63mm otherwise your wasting your money on the larger throttle body.
Robert
Old 02-09-2008   #9
Default Re: 63mm TB
I just checked my car, it has the 415DRM package....
TB measures to 63mm
Intake opening 60mmm???????????????????????
Good catch Dominic! I assumed they would have opened it up since the intake was extrude honed, etc. I'll put that on the list.
92 ZR1
#234
Old 02-09-2008   #10
Zr1 Destroyer
Zr1 Destroyer's Avatar
Default Re: 63mm TB
Get in touch with Greg V. in Oklahoma.....he did nj's last year and was the largest one has has ported to date! It's so nice lookin it was a shame to mount on the car instead of using it for wall art!
....and the finished results......
Zr1 Destroyer is offline   Reply With Quote
