Just curious..where does the your (obviously the ZR-1) oil pressure guage sit when first start up? After warm up at idle? and at lets say 4K rpm? Mine seems to sit at about 3/4 up on the guage constant except at higher rpms a couple ticks below 80. New oil, filter etc so am just wondering if the gauage reading is the normal mode?
Michael |
![]() Join Date: Nov 2006
Haven't ran mine for about a month
I began reading about the some what common pressure sender issue...where is the oil pressure sensor sending unit located?
Michael |
It's just inboard of the right water outlet pipe on the oil filter adapter sitting vertical, plug is easy to pull off and look for oil, one of the easiest things to get to.
Got it! Good info and big thanks
Michael |
i had an interesting thing happen recently. changed the oil and filter and the pressure wnt down on the gauge alot . to half way when hot . scared me a bunch . got another filter screwed it on and poof things were back to normal. anyone had this happen to them also?
