Old 01-22-2008   #1
bradslt5
Default where is the vaccume pump fuse
my vaccume pump works when hooked directly to the battery .but i turn the ignition on and nothing. in looking at the electrical page it says in line fuse in engine compartment,but i cant find . help where is that little bugger?
Old 04-03-2008   #2
zr1con
Default Re: where is the vaccume pump fuse
Hi, i have that problem to , did you find the fuse ? what was wrong?
Ben
zr1con is offline   Reply With Quote
Old 04-04-2008   #3
Somewhere here there is a picture of the location of the fuse.
driver's side rear fender linner, ya know our linners are 3 parts, so it's the part closest to the battery.
The fuse is in a holder secured by a screw into the liner. I think you can see it just in the area in front of the ECM but down by the top of the rear liner. It's just a small box with 10AMP imprinted on it...I think..I'm pretty sure.
Anyway there is a photo here somewher of the fuse.
Old 04-04-2008   #4
bradslt5
your right about the location and the 10 amp fuse
