Old 01-18-2008   #1
Default F/S:Better Dowty Washers for Cam Covers
NEW Dowty Washers: Better sealing because (1) it also seals around the bolt, whether stock or aftermarket with full size shank, (2) wider seal, (3)it is self centering and won't leave the thin seal in the gap between the bolt & cam cover hole and (4) less expensive.
Sold in complete set of 48 pkg only = $49.75
pkg will contain 50 dowty washers in case you drop & lose a couple...
http://jerrysgaskets.com/store2/root...products_id=30
Shipped U.S. Priority Mail. No extra charge for additional packages if you want more than 1 set. Contact me for shipping quote if you require international shipping.
Here is a photo so you can see the difference between the new one and the OEM dowty washer.
Old 01-19-2008   #2
DMark
DMark's Avatar
Default Re: F/S:Better Dowty Washers for Cam Covers
These look great!
Makes one wonder why they weren't done that way in the first place.
Refresh my memory - Where does the "Full Size Shank" bolt go?
DMark is offline   Reply With Quote
Old 01-19-2008   #3
Originally Posted by DMark
These look great!
The aftermarket, stainless steel, allen head bolts are full shank. I didn't have one handy for the pictures, so used a different bolt with same characteristics.
Old 01-19-2008   #4
DMark
DMark's Avatar
Jerry,
Thanks - - - I was all confused, was afraid that I didn't have the correct OEM cam cover bolts.
Old 01-20-2008   #5
phrogs
phrogs's Avatar
Jerry,
Come on that motor was never cracked open I even tried to get Ed to do it he wouldnt
JOHNNY P
Currently own
Old 01-20-2008   #6
DMark
DMark's Avatar
Well Johnny - It won't be a virgin much longer!
