Old 01-12-2008   #1
MikeG
MikeG's Avatar
Default HELP! Changing the WaterPump
I've got a 91 that I need to replace the waterpump on. A friend, who has a nice shop, but no ZR-1 experience, looked it up and said it was a 5 hour job and would cost $ 375+. In checking my Chilton, from the step by step, it doesn't look like that bad of a job. But since I can't even see the darn thing and having to lay on my back or bent over the side for 5 hours, which will probably mean 8 or better, the way things go, and then since the garage is unheated and it's in the 20's for the next couple of months, it's not a project that I'm really excited about.
Have on had the ZR-1 for about a year and am still getting used to the Beast! Anyone out there that has changed the pump themselves?
Mik
91 Turquoise Mettalic #135
MikeG is offline   Reply With Quote
Old 01-12-2008   #2
ShawnZR-1
ShawnZR-1's Avatar
Default Re: HELP! Changing the WaterPump
Yep, 5 hours sounds about right. It's not the easiest thing to get to and there are a lot of hidden bolts!
While you're in there, change the hoses if they haven't been changed in the last few years. If they're original, you might wind up cutting them off anyway!
1991 Chevrolet Corvette ZR-1
ShawnZR-1 is offline   Reply With Quote
Old 01-12-2008   #3
Nope, still got my replacement in the box, but if you have those sprung steel clamps vs the "ideal" screw type clamps....go & buy the special remover tool, the up-scale one at that...it has the grasper on the end of a long cable...you'll need it & it will make life a bit less stressful, fighting with the hose clamps, that is if your 91 used the same clamps as my 90.
Not knowing the FSM steps, I haven't looked because I don't relish doing it...it would seem to me that the fans at least would have to go for the job to be even remotely pleasant. I could see r & r'ing the rad too, as it isn't that bad, just to have more room to stick my fat head in there to see what I was doing. Might even have to dis-mount the steering cooler for some room & the tensioner, p/s pump, jez...this seems like fun. I think I'll shut up now.
Oh yea, I hear ya about the unheated garage.....I got no heat & no recepticals in mine & the overhead light stinks. You have my empathy, I hope it goes smooth for ya!
Old 01-12-2008   #4
cuisinartvette
you can do it without removing radiator, the hoses gotta go, think I took the air horn off too. If I remember right I didnt get the lower hose completely off the water p[ump til I had broken it loose, it was a pain to get the clamp off.
There are a bunch of bolts that come out, and some that look like theay are supposed to but dont (think those go into the timing chain cover). Get a fe cans of brakleen and spray everything off real good so you can get a closer look at what youre doing. Dont forget the ones right above the balancer, hard to see them. Make sure you keep track of what bolt goes in what hole, I believe some of them are differerent.
Its not too bad, just takes patience. WIll go together much quicker than it came apart.
Old 01-12-2008   #5
UKZR1
UKZR1's Avatar
That sounds about right. It was a couple of years back but I remember taking the pump out with the fans etc in place. Think I removed the belt and the air horn and then located and removed the bolts by feel after looking at the replacement for an isea of where they were going to be. Not a nice job due to the lack of space. I removed the spring clamps with pliers but have since bought the proper tool for the job - go get it it makes things sooo much easier. From memory i pulled the pump with the lower hose still attacthed and then removed it when I could get to it.
If its any help, there are some photo's of my LT5 sitting out of the car on my site. You can clearly see the water pump in position.
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
Old 01-12-2008   #6
petefias
As I recall there are several different lenght bolts coming out of the WP. Lay the new pump next to the car and transfer the bolts as you remove them from the old into the appropriate hole on the new. Once you removed the old pump transfer the bolts back to the old pump. As you install the new pump once again install the bolts one by one by transferring them from the old pump to the new one.
This will guarantee you use the bolts where they belong. You will be glad you did this "childish game"...
Old 01-13-2008   #7
Thanks guys, I'm taking notes!
Old 01-13-2008   #8
Hammer
Hammer's Avatar
Talking Re: HELP! Changing the WaterPump
Mik
Nice to see you over here Mike. Glad these guys can help. I haven't had to do this or I would have posted.
Old 01-13-2008   #9
cuisinartvette
Wanted to add when reattaching the WP leave the lower hose off. Once its secured you can get the hose on, I just used a regular ol clamp instead of the stock one. Leaving the hose on and tryuing to line up the bolts...good luck. For some reason I remmeber having to remove a bolt/few from the alternator.
Maybe Jeff can fill in the blanks here.
Old 01-13-2008   #10
MikeG
MikeG's Avatar
Gixer, thanks for the post and the link - could you be a bit more specific on where to look on your site for the pic mentioned. Checked your site a bit - looks great and will look more indepth - but not sure where to look to see the motor,
MikeG
91 Turquoise Metallic, # 135
