Old 01-06-2008   #1
Kevin
Kevin's Avatar
Default non-zr-1 question...
I have a buddy that has a 90 L98 and he needs an abs sensor. he told me that they were NLA, does anyone know where to find one.
Old 01-07-2008   #2
Jeffvette
Default Re: non-zr-1 question...
Front:
RH 14104822
LH 14104821
Rear:
RH 10052274
LH 10052273
I assume he needs the front, but which side.
Old 01-07-2008   #3
Kevin
Kevin's Avatar
thanks jeff. I have no idea at this point I just got the information second hand from a friend who talked to him. I'll try and get more info tomorrow
Old 01-13-2008   #4
Kevin
Kevin's Avatar
jeff,
it's actually the abs module not the sensors
Old 01-13-2008   #5
Jeffvette
Originally Posted by Kevin
jeff,
Kevin, it is discontinued. You might try with phrogs to see if he has one available since he is parting out a 90.
Also there is a new one available, but it's 800.00
Old 01-13-2008   #6
Kevin
Kevin's Avatar
do the ZR-1 and non zr-1 use the same part?
Old 01-13-2008   #7
HADI-ZR1
OK...OKK.
Listen just show me where this abs module , so i go look for used
or new and i will let you know, just give us the part number,where it located in the car?
i dont think this item is pricey!
Old 01-13-2008   #8
Jeffvette
Yes they do.
Old 01-13-2008   #9
Jeffvette
Here you go Hadi, knock yourself out 10223326
BTW, just to save you some time, here is GM's pricing on the part.
Old 01-13-2008   #10
HADI-ZR1
No problem Jeff.
I think used one(clean) from 93-94 corvette will be cheap, specialy if i found it here in kuwait.
when i will be free i go for it.
what about USA made module(not GM) ? i think would be half price.
we have GM corvette parts here which is cheaper than in USA.
Dont know why ,but its true.
