Old 01-05-2008   #1
RiceEatingZR1
RiceEatingZR1's Avatar
Default c5 Z06 Calipers
I am thinking about upgrading to the c5 Z06 Calipers front and back. the questions I have are:
1: is it a simple bolt on replacement?
2: should I then use c5 Rotors and brake pads?
3. on the rear how will it effect the Ebrake?
Thanks for the help in advance!
RiceEatingZR1 is offline   Reply With Quote
Old 01-05-2008   #2
Polo-1
Default Re: c5 Z06 Calipers
You need to talk with Jeffvette
C5 rotor does not work with C6 Z06 14x1.250
Old 01-05-2008   #3
RiceEatingZR1
Opps I ment c5 rotors..
Old 01-05-2008   #4
Paging Jeffvette
Old 01-05-2008   #5
Jeffvette
Yes it's simple. When doing the fronts and with the bleeding, it should take no longer than three hours start to finish.
You can, or you can use base C6 rotors. Pads I recomend the Hawk HPS. I would also recomend using the base C6 caliper as it is a better piece than the C5.
Don't worry about the rear, just refinish the rear caliper to match the front.
Old 01-06-2008   #6
RiceEatingZR1
Thanks Jeff! Do I need any adpters for the new calipers? or will they just bolt right up?
Old 01-06-2008   #7
Jeffvette
Added picture in my above post showing my bracket.
Here is a link to the instructions
http://www.pnwzr1.com/brake_install.htm
Old 01-06-2008   #8
Jeffvette
Here are some shots showing the difference between the C5 and C6 calipers.
Old 01-06-2008   #9
cuisinartvette
I like those!! What would a complete setup cost for those thinking about it, Jeff?
Old 01-06-2008   #10
RiceEatingZR1
Will they fit with the stock 5 point rims?
