![]() Join Date: Apr 2004
I changed my plugs this weekend and did compression check. 91 46K miles..by the way did it cold. as I was changing plugs..
200 205 215 205 200 210 205 225 ? is about the 225???
Test needs to be done with the engine warm... or at operating temps. Numbers are supposed to be in the 150-200 psi.
what kind of differance will I see warm vs cold?
#4 | |
228 230 226 230 225 228 225 230
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 12-10-2007 at 03:36 PM. |
LOL, seems like the book numbers may be off. They are all within acceptable range of each other.
But high compression numbers can lead to detonation. |
Thanks that is what I have been having issues with detonation. went down 2 heat ranges on the plugs and it went away with the stock prom....Can't run the SGC prom with out getting 1 to 3 knoxs as I roll ito the throttle.
If you really wanna put your motor to the test do a leak down on it!
I agree . a leak down is really a tell all . summit has a good unit for just under a c note
#9 |
I'll check them out...thats the one tool I don't have...yet
![]() These are from the snap-on scantool before plug change AC Rapid Fire #5 about 30K miles on them Hot Chip INT..L...129 R...128 BLM..L..128 R..136...only ran at temp for about 10min. no more than 30mph MAP..1.12V Hg 9.2 TPS Closed...54 BPN L..3.8 R..4.0 O2..L..93 to 677 R..106 to 646 IAC..30 Spark Adv. 10-11 @ idle 900rpms the most adv I got was in the low 20s Lots of ping & Knox Stock chip INT...L120-124....R120-124 BLM..L125....R131 about the same run time MAP 1.24-1.26 hg 10 TPS closed.54 BPN.L4.0 R4.0 O2 L115-655 R155-668 IAC..20 Spark Adv. 8-10 @ idle 675rpms most Adv. 18-20 Some ping & Knox After plug change NGK BKR7EIX Hot Chip INT..L...129 R...129 BLM..L..130 R..130... ran at temp for about 100 miles MAP..1.12V Hg 9.2 TPS Closed...54 BPN L..4.0 R..4.0 O2..L..93 to 677 R..106 to 646 IAC..30 Spark Adv. 10-11 @ idle 900rpms the most adv I got was in the low 20s 1-3 knoxs & still some ping on throttle roll in Stock chip INT...L-128....R-128 BLM..L125....R125 about the same run time MAP 1.24-1.26 hg 10 TPS closed.54 BPN.L4.0 R4.0 O2 L115-655 R155-668 IAC..20 Spark Adv. 8-10 @ idle 675rpms most Adv. 18-20 No knoxs on throttle roll in I'll stick to the stock prom until I have time to get another tune.
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 12-10-2007 at 06:55 PM. |
#10 |
corey henderson has some cool tunes for a basicly stk motor (210)867-6286.
