Old 12-04-2007   #1
ZR1ROB
Default How to get rid of code 22
I'm looking for bug spray to quash this Code 22 once and for all. TPS Low.
Its intermittent, and SES comes on sometimes when driving. Idles fine at start, but after the code has appeared during the trip, its idling at 2K.
I've replaced the TPS twice, and tested the low voltage ~ .5V
ZR1ROB is offline   Reply With Quote
Old 12-04-2007   #2
gbrtng
gbrtng's Avatar
Default Re: How to get rid of code 22
Most likely you have an intermittent connection between the TPS and the ECM, or the ECM's 5 volt reference is flakey. Check the connectors at the TPS and the B-connector at the ECM for dirty or bent pins. Finally, borrow a TECH 1 and follow the diagnostic aids in the service manual for code 22.
