Old 11-20-2007   #1
Jeffvette
Default Winter special
Well, I know winter time is when most of you like to do your mods as you want to drive your cars when the weather is nice.
This will be good from 11/22/07-2/29/08. So you have 3 months. To get this deal I must have the parts in my hand no later than the 29th of Feb.
Package 1:
Engine refinishing color of your choice. With return shipping for US customers and a complete set of gaskets to do reassmeble the motor. 350.00
Package 2:
Add in porting for the plenum & injector housings for an additional 900 for a total of 1,250
The gaskets included will be all three TB gaskets, plenum and injector housing gaskets and the coolant outlet pipes.
Old 11-20-2007   #2
Hack
Default Re: Winter special
I am very interested! I will talk to you about this more in depth when I come to pick up my car.
Hack is offline   Reply With Quote
Old 11-20-2007   #3
Ccmano
Jeff,
Can you list the parts we would need to send you for the whole works?
Thanks
Hans
Old 11-20-2007   #4
Jeffvette
Glen, if you want you can skip picking it up and I can get started on it. I'll call you back in a few minutes.
Old 11-20-2007   #5
Jeffvette
Originally Posted by Ccmano
Jeff,
Thanks
Hans
This is for the refinish
Air horn
TB
Plenum
Injector housings
Coolant outlet pipes
Cam covers
And if you want to
Hard pcv tube on the drivers side
Hard coolant line on the passenger side
Map sensor bracket
Map sensor cover
Old 11-22-2007   #6
Zr1 Destroyer
Zr1 Destroyer's Avatar
Wow.....that's a good deal!!!!!!!
Zr1 Destroyer is offline   Reply With Quote
Old 11-23-2007   #7
Air horn
TB
Plenum
Injector housings
Cam covers
And if you want to
Map sensor bracket
Map sensor cover
I can tell you Jeffs Work is outstanding he did my motor in July and it was an decison I will never regret. =D>
Old 11-25-2007   #8
bobbyhi
bobbyhi's Avatar
I'm seriously thinking of having you do the package #2 if I get the balls to tackle taking everything off the car . Looks like the cam covers will be hardest. Do you do the "Artic White" color? Also, do you do PayPal? I will probably PM with a couple of more questions before I decide. Thanks Jeff
Old 11-25-2007   #9
carter200
carter200's Avatar
While you are at it how about having those coolant pipes engraved and replacing that old throttle body plate with a billet engraved one. Just ship me your coolant pipes and I'll engrave than and ship them and the billet throttle body plate to Jeff for PCing with your other items. PM me if interested.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 11-26-2007   #10
cuisinartvette
Thats an awful good bang for the buck, more hp and looks the part, too.
Once day Jeff will do some 'coating for me and Carter-youll be getting some engraving work on those pieces if not come old school stuff before that.
