Old 11-06-2007   #1
Belsy
Belsy's Avatar
Default Scanners
What scanner does everyone like??? Need one for OBD II and early cars (pre 96) for the ZR-1, are there good / better / best or just an all around preference.
Belsy is offline   Reply With Quote
Old 11-06-2007   #2
Jeffvette
Default Re: Scanners
If you can swing them, Gm Tech 1 & Gm Tech 2.
But others work as well. Just not real familiar with them,
Old 11-06-2007   #3
bradslt5
how much are they and where can one get one . thankyou very much
Old 11-07-2007   #4
Belsy
Belsy's Avatar
What do you meen "swing them" are they heavy or just expensive??
Are you coming to SGC if so get with me if you need a ride from Fl.
Gene
Old 11-07-2007   #5
Jeffvette
Tech 2 is roughly 2k for the bare bones version. A tech 1 is 300-500 for a used one.
Let me see what I can do about coming down.
Old 12-04-2007   #6
TonyTZR1
I am looking for an ODB-1. Anyone know what they cost?
Thanks;
TonyTZR1 is offline   Reply With Quote
Old 12-30-2007   #7
flyin ryan
flyin ryan's Avatar
i got myself a used Tech 1. wouldn't be with out it.
Old 01-01-2008   #8
95ZR1
I have one of those Auto-Xray scanners - does OBDI and OBDII scans on the Vettes as well as the brand new cars. Doesn't do much other than return sensor readings and DTC's, but it works fine for me since I paid less than $200 new.
95ZR1 is offline   Reply With Quote
Old 02-11-2008   #9
Norsky4360
I've been looking for a unit that I can use on "The Beast" mainly. If it works on "The SilverBuckboard" (my '01 F-150) that would be a plus and on my bride's "Scooby-doo" ('04 Subaru Outback) that would be a bonus. I know nothing about these units but understand they can be a great thing to have in the toolbox.
Norsky4360 is offline   Reply With Quote
Old 02-12-2008   #10
95ZR1
Personally, I think the scanners are of limited value with the OBDI software, unless you have a very high-end unit. There just aren't enough sensors and stored values to make it worthwhile, and most of your problems aren't tracked by the software. The OBDII makes it much more worthwhile.
