I see a lot of Z owners mention 63mm throttle body as one of their mods.
Who makes it and about how much $? How does it differ from the stock throttle body and when does this mode make since? |
The two big blades inside the TB are a 58mm size. The bore is enlarged to 63m and new butterflies are cut out and mounted up.
Cost is around 300. The gain on a P&P plenum and injector housing set is minimal. |
#3 | |
Hans ![]() |
![]() Join Date: Aug 2005
thats an interesting topic...i also heard that 58mm is big enough to feed a 350 cu.in,no matter what kind of mods you have...any real world results?...dyno comparo?
bj 91/1735 |
I would rather see somebody put the 300 bucks towards headers than to modify the TB.
#6 | |
This is what Jeff told me 6 months unless you punch the block you are throwing your money away on this TB mod. |
How about if ya give it an upper -cut !!!!!!!!!!!!!!! Sorry couldnt help my self
IMO if a 48mm TB will support a 502 CI BB the stock TB should be plenty for the LT5 even with plenty of porting. Sure, its comparing 2v to 4v but airflow is airflow.
