Old 10-10-2007   #1
rogerzr1
rogerzr1's Avatar
Default Bose speakers
Do most of you still have the factory speakers. I either need to have my speakers rebuilt or replace the whole system. Just wanted to see what most have done.
rogerzr1 is offline   Reply With Quote
Old 10-10-2007   #2
Sgreg
Sgreg's Avatar
Default Re: Bose speakers
Speakers seldom go bad. Most problems are speaker amps and the power CDM. Radio is a slave unit only. What is it doing ?
Sgreg is offline   Reply With Quote
Old 10-11-2007   #3
RICHARD TILL
the speakers are the only thing that has`nt been repaired or replaced on my 90 model. i like my music cranked up so they must be mighty good quality.
Old 10-11-2007   #4
Z Factor
Z Factor's Avatar
http://zr1netregistry.com/forum/showthread.php?t=643
Old 10-11-2007   #5
rogerzr1
rogerzr1's Avatar
The speakers are make hissing and popping noises. When I can get sound out of them it is very faint. Also, I don't think my CD player is working. If I were to remove the speakers and deck, where would be the best place to return them. I have seen a number of places that will fix the amp on the speaker, but what if the speaker itself is bad?
Old 10-11-2007   #6
Tim
Sent mine to Florida to the doctor. Great service even though they were having a hurricaneat the time, and they sound great. Have fun getting the cdm box out!! Just TAKE YOUR TIME.
Tim is offline   Reply With Quote
Old 10-11-2007   #7
Jeffvette
They were gone a week after i had the car.
If it says Bose, you know it blows.
Old 10-11-2007   #8
rogerzr1
rogerzr1's Avatar
Jeff - What type of system did you end up replacing the old one with? Sounds like you are not the biggest fan of Bose.
Old 10-11-2007   #9
evl_twn
evl_twn's Avatar
BOSE = Buy Other Stereo Equipment
The only reason I still have the stock system in mine is I like the matched "look" of the controls, illumination, etc. It would be somewhat of a pain in the *** to gut the whole system, but any current system will blow the BOSE out of the water. You have LOTS of options on speakers, too. A lot of people are even putting a full range up from and just putting a set of 8" subs in back.
Edit: also, look at features of current systems. You're not limited to radio/cassette/CD anymore by going aftermarket. Now you can add mp3, hard drives, XM/Sirius, bluetooth, the list goes on and on. Some new head units also have a USB connection, you can just load up a jump drive and play mp3 from there.
evl_twn is offline   Reply With Quote
Old 10-11-2007   #10
Jeffvette
Went with an older alpine deck I had pulled out of one of my old cars. It's now ten years old and never given me a lick of trouble.
Also a alpine Digital EQ, Alpine amp and MB quart speakers mounted in the stock pods.
