![]() Join Date: Dec 2003
A friend called a mentioned there will be 2 C6 ZO6's at the track so got the Z ready and went out.
I wanted to see what i can do next to a C6 ZO6 one stock,the other w/headers filter & tune 496 RWHP i figure i would loose but still wanted to see how hard they pull at the top half of the track. The stock ZO6 didn't make it,now i knew i had no chance with the moded ZO6,even with my BFG DR's to his F1's and his 496RWHP to my 463RWHP The KING did me proud i made 3 passes First pass testing traction: 1.97 60ft 97.31 11.75 @ 124.05 Second Pass: 1.75 60ft 97.56 11.43 @124.22 Got a warning slow it down. Third Pass: 1.76 60ft 97.83 11.44 @ 124.58 Second Warning Went Home C6ZO6 ran two 11.90's @ 123,i guess HP doesn't compensate for driver ![]() This is my best MPH i've run. My best ET was last year 11.35 With front runners hello 126 MPH. ![]() Remember i have stock bottom 350c.i. w/3.45 gears Pete P.S. NJ why did you edit the heads post in CF, did you get the call LOL.
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 09-27-2007 at 02:35 PM. |
good news. keep going
![]() what the mod on your ZR ? ![]() |
![]() Join Date: Mar 2004
Nice going Pete !!
Nice!
All right pete . glad you got a chance to go to the track. you still have the stk gears. would 410s help ya think ? i am wondering if i should go back to 345s my self . what were your starting line tec. what tire pressures ? have you modded the reayr suspenson? good tohear from ya . those times deserve a glass of armenyak/=D>
Pete,
Was that Byron or Great Lakes? You coming to Byron on the 20th? I may have headers on by then. |
Way to go ZR-1 Pete great MPH gotta luv it.. a 6th gen modded Z06 barely in the 11's and only 123--must be a newbee
keep up the great work!!! |
#8 | |
Brad i would rather sacrifice some 1/4 ET for the highway i like going to 60MPH in 1st gear and 155MPH in 4th. I started with 25 PSI for the first 2 passes,it was good but hitting 2nd and 3rd so hard i was getting tire spin i figure i was loosing some MPH on the 3rd pass went down to 22PSI still got some rubber on the shifts not as much. First pass was test the track/traction ain't trying to kill myself with a 5k RPM drop without knowing track conditions,last time at this track with same tires had no traction The first run was 2500 drop,second 3500,third 4200 w/lower tire pressure it hooked real good and got me some bog this is where the 4.10's would help i think 3.73 would be a better choice for now i'll stick with the 3.45's Suspension is all stock beside the longer rear bolts,the FX switch was on Sport. Thanks for the drink but i don't drink alcohol i'll take a Diet Pepsi ![]()
#9 | |
I will try to make it out to Byron on the 20th. Pete
#10 | |
Ported Top End (Heads,IH's,Plenum) 63mm TB Marc Haibeck Intake Cams .236 .430 Jeal Headers B&B (Real Old Design) StainlessWorks X-pipe W/Dynomax 3" bullets Electric Water Pump UD pullies & Thermostat from ZR1Products No secondaries and a good tune. Pete
