Old 09-23-2007   #1
kenthompson
kenthompson's Avatar
Default Walbro pumps
Has anybody had experiance using Walbro fuel pumps as a replacement for the fuel pumps in a Z?
I was thinking about this. What would be the reason it couldn't be done?
KT
kenthompson is offline   Reply With Quote
Old 10-11-2007   #2
ZR1_170
Default Re: Walbro pumps
I can be done there is alittle to mod but it is not bad I have a Walbro pump in both. On mine the Walbro pump was wider than the stock one and the sleve that the stock pump sits in had to be cut to open up some more room.
ZR1_170 is offline   Reply With Quote
Old 10-11-2007   #3
jonszr1
jonszr1's Avatar
just curious, why the walbro pump? does it flow more?is it less expensive. ? I deal with this brand alot in my business. if someone needs a couple of them give me the part # as I deal with them direct and my price is pretty good. have a great day
Old 10-11-2007   #4
kenthompson
I finally got a response. Yea!
I almost thought I was pioneering again.
So, would it be better to aquire another float assembly and hack that one? Just for purity's sake, in case somebody else wanted to "restore" the car?
KT
Old 10-11-2007   #5
kenthompson
Seems to be the one to run. All the Fbody (mullet heads) and Rustangs around here run them.
KT
Old 10-11-2007   #6
ZR1_170
KT
My car has a roll cage in it so I just cut the one in the car. I would say what ever you wanted to do but I think it comes from GM with the pumps all together so if you are going to do that just put it back the stock ones. I do not think the car picks up anything changing them I just did not want to spend the money on the stock stuff when I had two new Walbros that I did not use in my Grandnational just sitting around.
Old 10-11-2007   #7
kenthompson
That's what I thought, a less expensive route if I needed to replace the pumps.
Old 10-11-2007   #8
so which walbro pump did you use? the 255lph one? or the 190 lph?
Old 10-12-2007   #9
ZR1_170
two 255's
