Old 09-21-2007   #1
kenthompson
kenthompson's Avatar
Default PCV Valves
What exactly is the difference between the PCV valves in a LT5? When I replaced mine, I used identical valves thinking that is was merely a volume issue. Is it a vacumn issue, or a "timing" issue, or something else? I tried to search for "pcv valve", but it didn't find anything.
KT
kenthompson is offline   Reply With Quote
Old 09-21-2007   #2
jonszr1
jonszr1's Avatar
Default Re: PCV Valves
they open a t different levels of vaccume.if you notice that one spring is lighter than the other . to give a broader range of vaccume. not much space in the bottem end is my understanding. i also found on my car i used lessoil when i revrersed the pvc valves.it could be that the car is a little strange like its owner
Old 09-23-2007   #3
kenthompson
I wouldn't be sure the one's I pulled out were originals. No numbers on them.
Car doesn't smoke (except for the first ten minutes after I put the PCV system back together), now I'm wondering if I did something wrong.
KT
Old 09-23-2007   #4
jonszr1
jonszr1's Avatar
Of you live on vegas you should go find the guys that are there for the gathering . ck the sched .up top .
Old 09-23-2007   #5
SDZR-1
Does anyone have the part numbers for them both....because I'm not 100% sure that the guy who ordered mine knew for sure if they were correct....thank you
SDZR-1 is offline   Reply With Quote
Old 09-24-2007   #6
kenthompson
I'm looking forward to it.
I'm hoping Haibeck (sp?) shows up.
KT
1990 Grey/Black
Too many for the sig.
Old 09-24-2007   #7
1990 quasar blue
Driver Side CV913C Pass Side CV769C
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 09-24-2007   #8
SDZR-1
thanks
