Old 09-09-2007   #1
bobbyhi
bobbyhi's Avatar
Default 1990 Radiator
I have been loosing antifreeze for the last couple of days. Only happens when the car is hot. Nothing when cold. It appears as if it is the radiator. Can't find any other leaks of any sort except the lower right corner of the radiator cover. I will have to check it out a little further. How I'm not really sure but there must be some way. If it is the radiator I need suggestions as to where to purchase and what kind should I buy. I do not do any track racing so maybe a stock (if available) would work OK. Don't want to spend an arm and leg but it is something that needs to be replaced. 66M on the clock and doesn't overheat when driving. Any suggestions will be helpful.
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 09-09-2007   #2
cuisinartvette
Default Re: 1990 Radiator
Sounds like the tank may be starting to split/seep. The replacements from what I understand come with a trans cooler, I dont know what effect if any that has on keeping the beast cool with less capacity. Sounds like most here like the DeWitts as a replacement.
1990 ZR1, 142,000 miles-Black on black
4.09's Haibeck chip, 3"exh, K&N, meth inj.
Old 09-10-2007   #3
When I had my rad out for cleaning I noticed in the FSM a "how to" tighten the metal spring steel clips that hold the plastic tanks on the core.
I checked mine for tightness and some were a bit looser than others so I used a small pair of channel locks to re-crimp the suckers. This seemed to cure this "coolant smell" I would get sometimes after a good run....no drips and not missing any measurable volume of coolant, just this smell sometimes.
Also, if you look them over & see some hair line cracks & have one of those testers, you could pump her up & look for air leaks. If you find any in the plastic a little epoxy high temp resin + some fine "racing cloth" will seal up the small cracks, get that stuff at a boat supply store. Even if you have a split, use some Marine-Tex epoxy on the big ones with a bit of 10 oz cloth.
I know this sounds like the a$$ backwards way to fix the side tanks but the GM replacements rads all have a trans cooler & our OEM rads do not....and ya can't buy the side tanks or at least I haven't found any one who sells them.
Old 09-10-2007   #4
Mika73
I got BeCool radiator and it runs nice and cool. Also -90 ZR1.
Mika73 is offline   Reply With Quote
Old 09-10-2007   #5
DaveK
Hey Bob
I heard that those 49th Street rockers cause all kinds of problems like that. You should give them away right now - to me
Good luck with the rad replacement. Let me know if you need help installing, I'll drop by for the weekend
Dave
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 09-10-2007   #6
Hammer
Hammer's Avatar
Talking Re: 1990 Radiator
Bob,
I changed my radiator to a replacement from the thepartsladi on ebay. Cheapest GM replacement I could find anywhere. I have the Haibeck chip like you and it works fine. Looks like two choices now. Good luck.
http://cgi.ebay.com/ebaymotors/90-91...3382QQtcZphoto
http://cgi.ebay.com/ebaymotors/90-91...2929QQtcZphoto
Old 09-10-2007   #7
Sgreg
Sgreg's Avatar
I have a very good OEM radiator take-off at about 20,000 miles I am selling for $85. An alternative to buying a new OEM or expensive aluminum replacement. If you are not racing you probably don't need an aftermarket radiator.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 09-10-2007   #8
bobbyhi
bobbyhi's Avatar
Originally Posted by Hammer
Bob,
Didn't know what the difference was so I ordered the first one. Looks like the same GM #'s. Thanks for all the help. I'm sure that I will be back on line here once I attempt to remove and replace.
Bob Anderson
Founding Member #19
Old 09-10-2007   #9
bobbyhi
bobbyhi's Avatar
Dave, the white panels would look too gaudy on the black beast Of course it might make it go faster!!!!
Bob Anderson
Founding Member #19
Old 09-10-2007   #10
DaveK
Oh well.. it was worth a try.. you could always throw in a tin of black paint too..
davidmkelly.com
