09-05-2007 | #1 |
Time to replace injectors
Looks like I've milked the original injectors as long as I can. Seems one of the secondary injectors has died a quick death. I'm planning to use the Accel injectors since others seem to have good luck with them. I also plan to replace plugs and plug wires while I'm that far into it. Planning to use GM wires and plugs.
Aside from ordering o-rings for the injectors and new plenum gaskets, is there anything else I should need in the way of parts to do this job? I've looked at the procedure for R&R of the plenum. Are there any tips/tricks for the R&R of the injectors? |
