Old 08-15-2024   #1
scorp508
Question Time to remove/replace Stainless Works headers?
How long (measured in beers, time, swears, whatever...) does it take to get a set of Stainless Works headers out and back into the car? Do they drop out the bottom or go in the top? I am planning to weld a couple wide band O2 bungs into them. I have a 4-post lift and all the usual tools. I've already had the exhaust behind the headers out, so I can do that pretty quickly.
What gaskets are recommended to go back on with?
Thank you.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 08-17-2024   #2
Default Re: Time to remove/replace Stainless Works headers?
Thank you.
https://www.jerrysgaskets.com/gasket...r-90-95-7-5b6/
Old 08-17-2024   #3
MRBOHN23
MRBOHN23's Avatar
Ever do the swap? How bad was it?
MRBOHN23 is offline   Reply With Quote
Old 08-18-2024   #4
scorp508
I have not as this '94 came with them already installed. I've done other C4s and it wasn't too bad.
Old 08-19-2024   #5
Starman
Starman's Avatar
They come out the bottom fairly easily.
Starman is offline   Reply With Quote
Old 08-26-2024   #6
MRBOHN23
MRBOHN23's Avatar
Ok, I may tackle this in a year or so!
Old 08-30-2024   #7
5ABI VT
with the exhaust off and under the car.. 10-15 mins per side. i pulled mine out and had them coated.. then wrapped. didnt like the wrap had them out in about the same time and took the wrap off. theres plenty of room and easy access
Old 09-02-2024   #8
bmarcum
10-15 mins per side. You work on a nascar team. That is awesome. You are way faster than me!
bmarcum is offline   Reply With Quote
Old 09-02-2024   #9
Mystic ZR-1
Mystic ZR-1's Avatar
10 - 15 minutes?
Using a smoke wrench?
Old 09-02-2024   #10
bmarcum
Just a detail question but does everyone get every bolt reinstalled on their headers? I hate exhaust leaks an my last Z 90 VIN 103 had a manifold leak that I would fit every two years. Some say that you can't get all exhaust bolts installed, but I disagree.
