Old 07-14-2024   #1
scorp508
Question What vaccum line is this?
I noticed this disconnected line on my 94 while my toddler was pointing at things and asking what they are. I havent had a chance to bust out my FSM or see if there is a vaccum when the car is running on it.
Keep in mind this car has its secondary system deleted.
Old 07-14-2024   #2
geezer
Default Re: What vaccum line is this?
The line from the vacuum pump would have gone into it.
geezer is offline   Reply With Quote
Old 07-15-2024   #3
scorp508
Thanks, geezer. Hopefully the other end goes to a check valve or is just disconnected. I'll double check if it is creating a vacuum leak or not.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 07-15-2024   #4
Sure that?s not the TB coolant that runs along the plenum?
Old 07-15-2024   #5
tpepmeie
that's the vacuum line from the pump to the SPT actuator solenoid. It almost looks like it's plugged? If the pump isn't running continuously, then it might be plugged down there too.
Old 07-15-2024   #6
scorp508
You're right, that does look like something is in the end. I'll take a look tonight.
That's gone, nothing to run.
Old 07-16-2024   #7
scorp508
I confirmed that is a plug in the end of it.
Old 07-16-2024   #8
tpepmeie
I can't remember, are your secondary throttles deleted?
Old 07-16-2024   #9
scorp508
Yes.
