Old 04-24-2024   #1
Matt B
Matt B's Avatar
Default HVAC control unit issues
I occasionally have random ssues with my air conditioning. Such as
- system spontaneously falls back to "default" mode (24?C, AC on, all on "Auto", etc)
- system won't react to pushing any control unit buttons
- led flashes with no noticeable impact or failure code set
- led flashed with low refrigerant failure code but AC blows ice cold
- led flashed with low refrigerant failure code and no AC operation. Battery disconnect fixes the issue and AC works fine again with no codes
I suspect that the HVAC control unit has issues.
Is there a fix such as swapping capacitors as you normally do on Bose the various Bose components?
Or will swapping the whole unit be the way to go?
I'd prefer a fix as my unit ist like new...
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 04-24-2024   #2
Starman
Starman's Avatar
Default Re: HVAC control unit issues
I had the same problems several years ago. Pulled the unit, replaced the caps and reheated some cold looking solder connections. Has worked perfectly since - over 12 years. Remember to pull the screw in the vent at the top of the center stack bezel.
Starman is offline   Reply With Quote
Old 04-24-2024   #3
KPW
KPW's Avatar
Same here, I used this kit: https://batee.com/collections/1990-1...estoration-kit
1991 ZR-1 #1438 Black/Black & Red
KPW is offline   Reply With Quote
