Old 04-12-2024   #1
scorp508
Question (Solved) Reading $F0 chip from '94 resulting in bad file?
EDIT SOLVED: I had my buffers backwards for a 32KB program on a 64KB chip. My Chip Addressing and Buffer Addressing were reversed.
It needed to be.
Chip Addressing: 8000-FFFF
Buffer Addressing: 0000-7FFF
After fixing that the file looks good.
Good ole' web archive: https://web.archive.org/web/20201128...using-offsets/
--- original post below ---
I'm trying to make a backup of the custom chip in 1994 #150 (Corey Henderson tune) for archival purposes in case anything ever happened to it.
I purchased a new chip reader/writer as my old one I used for L98 tuning 20 years ago was not even USB based.
This is what I purchased and it's essentially a clone of the Moates version. After Craig closed up shop and retired these folks have been carrying the torch forward.
https://boostednw.com/chips-and-adpt...ner-programmer
It is a 27SF512 chip in the car in a Moates adapter, a pretty typical setup.
If I read the chip with a 0000-FFFF buffer I end up with a 64KB file, but my understanding is the $F0 program should be 32KB. I changed my buffer to 8000-FFFF to get a 32KB BIN file as I thought the correct buffer was the last 32KB of the chip. I do have the chip with its notch towards the ZIF handle and the opposite end of the chip aligned with the "bottom" of the reader/writer.
Loading the file into TunerPro looks.... odd. Tables aren't smooth and things like fuel cutoff RPM show "60", yes sixty, instead of ~7,000 the stock BINs show. Injector flow rate is "0.39" which is also obviously wrong.
It has probably been close to 10 years since I messed around with these things. Am I forgetting an obvious step? If I load a stock BMCB file with the same $F0.xdf file everything looks normal. I tried 8E, F0, and F0A on the file with all the same results.
I'll toss it back in the car to make sure it didn't somehow get zapped in the 15-foot walk from the car to the laptop.
Old 04-13-2024   #2
Raykahn
Raykahn's Avatar
Default Re: Reading $F0 chip from '94 resulting in bad file?
Glad you got it solved.
For anyone else that might be looking at getting into this aspect of the cars, you can also get a chip reader from Burton Racing that is plug and play with TunerPro RT
https://www.burton-racing.com/collec...ts/chip-burner
Both it and the one from BoostedNW can erase/rewrite the 'fake SST' chips made in china by switching to a 14v mode.
Raykahn is offline   Reply With Quote
Old 04-13-2024   #3
Remember there is an $F0 and $F0A
Also what are you using as a logger?
Old 04-13-2024   #4
tiegsd
tiegsd's Avatar
Interesting. Would like to know more about what exactly is on the EEPROM in my ZR-1. Is there any other firmware in the ECU besides EEPROM? So far aware of the motorla chip, and the 2 proprietary Delco chips in the ECU, wondering what else goes on in there?
1990 Black/Black ZR-1 #1155
1993 White/Red coupe (Regrettably sold)
tiegsd is offline   Reply With Quote
Old 04-13-2024   #5
scorp508
The chip ID is set to 9011, same as BMCB, so I assume it's F0 based on this table.
https://zr1.net/forum/showpost.php?p=336837&postcount=6
I haven't gotten to that yet, but am open to suggestions. I have some ollllld EASE Diagnostics I used on my '87's OBD1 system, but this 94 is that hybrid OBD2 port with OBD1 system. I also have a Moates Ostrich 2 for emulation.
I may see if BoostedNW knows of any LT5s being datalogged with this, though it may need a 12->16 pin adapter for the OBD2 style port.
https://boostednw.com/Datalogging/gm...-gm-datalogger
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 04-13-2024   #6
scorp508
Jeff, is ALDLDroid still active? Most of the links for hardware to use with it on their webpage are long dead.
Old 04-13-2024   #7
Yes he (ALDL) just fixed something for me in Oct.. as for Hardware, if you have the molded ALDL cable, it is like $10-15 in parts
I use an Android phone and a USB ALDL cable. I have a Bluetooith adapter but never really used it. most of the bluetooth devices I think were Arduino based.
Cable seems to work the best for me. nice thing with the direct cable I have, the phone powers the adapter and I don't need the 12v Cigar adapter
Tags
$f0, custom, ecm, prom
