03-29-2024 | #1 |
Seatbelt retractor issue
My retractor locks during driving when the car hits a bump that is jarring enough or during spirited driving. Then it won't release and the belt continually gets a little tighter each time it happens to click another notch retracted. I have to unbuckle and let it retract fully so I can pull it back out.
Mine is a 1991. I thought I read that the retractors had an improved design in later years. Can anyone confirm what part is recommended to replace it or some other fix? |
03-30-2024 | #2 |
Re: Seatbelt retractor issue
1995 ZR-1 #106 Blk/ Blk Owned by me since 2000. 93K miles, but not on motor :-) Mods the way I want it, Not afraid to drive it! |
03-31-2024 | #3 | |
03-31-2024 | #4 |
I believe that to be the correct functionality for the seat belts..
03-31-2024 | #5 |
03-31-2024 | #6 |
Back in 1993 when I had my 89, I had the SAME thought, took the car to the dealer and was told that was the expected behavior. My 89, 90 and all the other C4s I have driven, all the same
03-31-2024 | #7 |
I can assure you it?s not normal or else the design was improved in later C4. I have never owned any other car that behaved this way. And my 1994 C4 didn?t have this issue. Maybe I will just buy later year retractors.
03-31-2024 | #8 |
The 1994 retractors I have will cinch the lap belt on their own after spirited driving. The shoulder belts do lock then release but the lap belts have always done this.. I have another set of belts from a 94-96
I can try but as far as I know the lap belts always worked that way
