Old 03-25-2024   #1
BlackroseZ
Default Cam Position Sensor Removal
Replacing the cam position sensor here in the next few days. It's in kind of a tricky spot and was curious if anyone had some tips on how to get it out without so much struggle.
Much appreciated.
BlackroseZ is offline   Reply With Quote
Old 03-26-2024   #2
Default Re: Cam Position Sensor Removal
I replaced mine years ago,it's no problem at all. I believe it's a 8 MM bolt and thats it. Not sure which replacement you have but on some the small shield for the sensor won't fit some replacements.
Old 03-26-2024   #3
Jagdpanzer
Jagdpanzer's Avatar
Be sure to place a small container below the cam sensor to catch the oil that comes out when the sensor is extracted.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-26-2024   #4
BlackroseZ
noted. Thanks.
