Old 03-18-2024   #1
scorp508
Default Heat gun to repair license plate frame?
The bottom center edge is bowed out a bit. I was considering taking it off the car, then putting some weight on it to hold it flat while warming it with a heat gun to reshape it.
Has anyone tried this and succeeded or wished they hadn't? I certainly don't want to ruin it. Thank you.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 03-18-2024   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Heat gun to repair license plate frame?
Should work. Be careful not to use to much heat. BTW the frame in the photo is upside down.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-18-2024   #3
aafc
aafc's Avatar
Hi, I do not know if this can be done, but its worth try. I have heated plexglass sheet when I made fixed headlights on my 1990 ZR-1. It was done in an old oven at 150 deg. Heat gun should work so heat it slow. Have your flat surface ready, then lay the license plate frame down, cover with cloth and heavy weight let cool completely.
If it doesn't work I had the ZR-1 rear license plate holder reproducted from
my original license plate frame. Cost is $150.00 plus shipping.
let me know if you need one. PM me or email at zr1john@gmail.com on
how to order.
Hope this works for you
1990 white/black #2546
one of a few 4l8OE eq ZR-1's
aafc is offline   Reply With Quote
Old 03-18-2024   #4
scorp508
Oh...then flipping it over may solve the issue if it's out of sight line!
Old 03-18-2024   #5
scorp508
Originally Posted by aafc View Post
If it doesn't work I had the ZR-1 rear license plate holder reproducted from my original license plate frame. Cost is $150.00 plus shipping.
Thanks John, I'll keep that in mind as a backup.
Old 03-20-2024   #6
scorp508
I flipped it and the eyesore is gone, for now, but maybe I'll heat it up in the future.
