Old 01-17-2024   #1
CDC
Default Spring guidance for a 1990 ZR1; FE1 = FHA? From England, GB
Hi. Firstly - i'm in England, Great Britain, just to set the tone. So my parts and shipping cost in general is another level compared to everyone in the USA.
I am desperately seeking a front spring (mine is an FHA) to replace my cracked one. No one on ebay.com will ship to the UK for some reason, so used ones seem sadly out of the picture.
Zip corvette seem to be the only place that has a new one. But they only stock two types.
The "base spring rate FE-1"
https://www.zip-corvette.com/84-96-f...ring-rate.html
Or the "sprint spring rate Z51"
I'm fairly sure neither of these are right to replace my FHA. I have reviewed the great thread on here with the list of spring codes.
Would appreciate your advice/assistance on this and whether the new FE1 option is actually the same as an FHA. Thanks!
Charlie
CDC is offline   Reply With Quote
Old 01-17-2024   #2
silver86
silver86's Avatar
Default Re: Spring guidance for a 1990 ZR1; FE1 = FHA? From England, GB
Found the following references in a thread from another forum, and from another decade. Can't vouch for the veracity, nor that this information will actually help you in your search:
Coupe, front
HMZ 84 w. Z51
BMB 84 base, 85-87 with w. Z51
HKX, HMP 85-87 base
FHA 88-91 base, 89-91 w. FX3&Z51
FHB 88-91 w. Z51
AA 90-91 w. ZR1
FSS 92-95 base, 92-93 w. FX3
FSK 92-95 w. Z07
FSM 92-95 w. ZR1
HA 94-95 w. FX3
22173028 96 base
17999032 96 w. Z51
Convertible, front
HMN 86-87
FHC 88-91 base, 89-91 w. FX3
FSR 92-95 base
JA 94-95 w. FX3
22173029 95 w. FX3
17999031 96
Coupe, rear
BMF 84 base
BMH 84 w. Z51
NYR 85 base(?) 86-93 base, 89-90 w. FX3&Z51, 90-91 w. ZR1
NYU 85-91 w. Z51, 92-95 w. Z07
RHY 92-95 w. ZR1, 96 w. Z51
RHZ 94-96 base
Convertible, rear
RCA 86-96
22112254 94-95 w. FX3
silver86 is offline   Reply With Quote
Old 01-18-2024   #3
silver86
silver86's Avatar
Just wanted to follow-up my post above:
https://www.zr1.net/forum/showthread.php?t=30468
Old 01-18-2024   #4
CDC
Thanks, but I am aware of the spring code info hence my comment "I have reviewed the great thread on here with the list of spring codes."
Old 01-18-2024   #5
Hib Halverson
My data shows the FHA spring was not used on a ZR1, but never say "Never" as according to Marc Haibeck, a lot of ZRs had FHAs
The FHA spring was 93.1 NM/mm which converts to 525 lb/in.
Here in the States, there are other sources for used Corvette parts than eBay and some of those vendors might ship internationally. Use keywords "used Corvette parts", "Corvette salvage", "Corvette dismantlers"
"J&D Corvettes" in California and "Corvette Recycling" in Utah are places to start.
Neither of those Zip Products springs will work as the base spring is likely a 22173028 which is 60 N/mm and the "sport" spring (out of stock) is likely an FHB at 115.5 N/mm.
If you can't find an FHA used the FSK may work
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-19-2024   #6
Thomas ZR-1
Thomas ZR-1's Avatar
Hi Charlie, I might have a FHA front spring in my shop...and shipping from Germany to GB shouldn`t be a problem. Can check it out in the evening and get back to you later.
[SIGPIC][/SIGPIC]Best thing in life is a ZR-1 ride
Thomas ZR-1 is offline   Reply With Quote
Old 01-19-2024   #7
tf95ZR1
tf95ZR1's Avatar
Another possibility:
https://www.eurovettes.com/
A friend of mine.
Good luck.
Ted
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 01-19-2024   #8
dredgeguy
dredgeguy's Avatar
You can always contact Mark at Mirrock Corvette www.MirrockCorvette.com
He will have what you need and sure he can arrange shipment.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 01-19-2024   #9
CDC
Thanks Hib. And I would also like to thank you for all the incredible reference material you have compiled for ZR1 owners like me. Your information on many ZR1 topics has been truly invaluable.
Old 01-19-2024   #10
CDC
Amazing. Please do sir.
