Heres a dumb question...........the first ZR1's had 375 hp , then it jumped to 400 hp, what change or addition made the difference in horsepower gain ?
![]() Join Date: Apr 2007
The '93 to '95s were rated at 405 HP. I believe the gains were due to some better porting and exhaust also with some chip tweaking but Marc and others could say more definitively. --Bob
I believe you are correct, porting and some change in cam grinding , gave it the 30hp gain . I know chevrolet used to retard cam timing years ago for emissions and hp reduction to meet standards.
![]() Join Date: Jan 2004
improved intake port alignment. Bit better heads and cams, improved exhaust and header/cats.
405 hp blocks also had 4 bolt mains and all of them were made in 1993 |
![]() Join Date: Jun 2005
>Mild port/polish on intake and exhaust ports.
>better blending of the ports just above the valve seats >Three-angle valve seats >"Sleeve spacer" between the head and injector housings to improve alignment >Revised cam timing but cam profiles remained the same >Revised calibration >New exhaust manifolds...which actually cost 5-hp but went to production to solve a problem with the engine ingesting debris if the cat converter substrate failed at high rpm.
#6 | |
#7 | |
![]() Join Date: Jan 2021
ZR-1 #638/1991 |
![]() Join Date: Dec 2003
That's because...... IF & When it does......... it Really is!
Referred to as catalyst reversion. Occurs during engine de-celleration, i.e. lifting throttle with clutch engaged at high rpm. All that's left of the Oil Control Ring lands, is that short section on the left end. ![]() ![]()
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 01-23-2024 at 05:57 PM. |
#9 | |
Some of that info came from GM press info that was distributed in the 1993 long lead book. The rest of it came from a conversation I had many years ago with Graham B.
#10 |
![]() Join Date: Jul 2017
Oh wow. Have to assume that happened to a few cars until someone figured out what was going on?!
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) ![]() |
