Old 06-12-2007   #1
kengodfrey
Default Wheels from 1990 Covette
Someone has two OEM rear tires for sale, 315/35/zr17. He says the tires are mounted on 1990 Covette wheels. (Not ZR 1 Wheels) When I looked up 1990 Corvettes, the wheels were only 9.5 inches, compared to ZR1 11 inches. Will these tires fit on 9.5 inch rims?
Thanks, Ken
kengodfrey is offline   Reply With Quote
Old 06-12-2007   #2
tccrab
tccrab's Avatar
Default Re: Wheels from 1990 Covette
Yes they will fit, however, they will look funny.
The tread of the tire will actually be a little wider than the wheel causing the sidewalls to be slightly concave.
I would think that this could potentially cause issues with the tire and maybe have a negative effect on handling.
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 06-12-2007   #3
UKZR1
UKZR1's Avatar
this shows a 335 on a ZR1 11" rim. A 315 on a 9.5" rim would be even worse.
pirelli 335/35/17 on my 1990 ZR1 wheel
this is how it looks now :
Max/min rim width for a 315 is 10.5 - 12.5" for a 335 is 11-13" as recamended my tyre makers
This guy selling them wouldn't be in the UK would he?? I ask because someone posted on a UK forum about fitting ZR1 tyres he had to a stock vette a month or so ago.
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
Old 06-12-2007   #4
Aurora40
Aurora40's Avatar
What he said. The tire needs to be approved for that. Every tire can be different, so check with the manufacturer. I wouldn't use it if it's not recommended that way.
Eagle F1 GS-D3: 10.5 - 12.5
Dunlop SP 8000: 11.0 - 12.0
Sumitomo HTR Z: 11.0-12.0
Bob Saveland
Former Owner of #2517
Old 06-12-2007   #5
UKZR1
UKZR1's Avatar
As 315's are no longer available over here, I talked to a Bridgestone tech guy and the bridgestone 335 is ok on our 11" rims, however I felt it would be pinched enough to affect the way the car handled and shipped a set of 315 F1's over from tirerack.
Years ago I fitted a set of 5 spokes on my Supra and fitted slightly over sized tyres on, in time cracks started to appear on the rear of the spokes
Marc Haibeck 368
B&B, Brembos
DRM suspension
