Old 10-27-2023   #1
Car-nutt
Default TPMS
Hello everyone, this is my first post. I recently purchased a 1993 Zr1, it only has 8000 miles and still has the original rims and tires in great shape. I have punched a set of extra rims with the car so that I can properly store the original rims and tires. I would like to have the car judged by NCRS. My question is can I purchase TPMS for the rims I am going to put on the car.
Car-nutt is offline   Reply With Quote
Old 10-28-2023   #2
zyal8r
Default Re: TPMS
Hi. Yes, I did this with my '95. I took the original wheels and GSCs off (supposedly they had never been off the car) a year ago and put a set of refurbished OEMs on it, plus a new set of Michelin AS4s in stock sizes. It took a little while to find another set of sensors, but I eventually found a set. A lot of folks will disable it or take the bulb out, I think it's kinda cool to have been one of the first TPMS systems around, and I wanted it to continue working, as long as I ran the same wheels. You're going to want the tan sensors for the '93-'96 cars. The black ones from '89-'92 won't work with '93 and up. Be prepared to pay $150-$200/sensor, at least.
Good luck!
Mike
1995 ZR-1 #004 - Yellow/Black
1996 LT4 #3828 - Yellow/Beige/LT4/Z51 - 1 of 4
zyal8r is offline   Reply With Quote
Old 10-29-2023   #3
Car-nutt
Default Re: TPMS
Thank you, If you don?t use the TPMS sensors the light will be on continuously or you can just pill the fuse.
Old 10-29-2023   #4
secondchance
Default Re: TPMS
You can pull the light bulb behind ?TPMS? warning light.
Old 11-04-2023   #5
Young1
Young1's Avatar
Default Re: TPMS
Carefully cut and positioned black tape is equally effective.
Steve Young
Second Owner
SOLD
SOLD
