07-20-2023 | #1 |
Infinity Lube
07-20-2023 | #2 |
Re: Infinity Lube
never heard of it ... and im an oil fanatic
07-21-2023 | #3 |
Re: Infinity Lube
A Buzz Lightyear product?
(sorry) https://www.fuelox.com/product/fuel-...on-eliminator/ Looks intriguing, but no, have not used it. Marty |
07-22-2023 | #4 |
Re: Infinity Lube
Just had a presentation at work on it. Claimed 40hp in engines. Dubious to say the least. Supposedly has been around for 30 years, given the lack of response, doesn?t appear to be a miracle I?ve missed out on.
07-22-2023 | #5 |
Re: Infinity Lube
My thought on 99.9% of additives!
Not sure what the other .01% is, but don't want to make an absolute statement!! Snake oil.jpg
Kenny 1990 #442 |
07-26-2023 | #6 |
Re: Infinity Lube
The info in the advertisement sheet says "900 degree flash point." At the bottom in the fine print it says "believed to be accurate at time of issue."
MSDS says 270 degree flash point. False advertising. So here's what we can deduce from the info they provide: - It's a plant based oil. - There is very little actual data on its chemical properties aside from flash point and kinematic viscosity. - The only actual wear test info provided has no data on what the actual test results were (like a scar size on a gear tooth or bearing) because "the weld point exceeded maximum limits." That doesn't sound good. Sent from my BBF100-2 using ZR-1 Net Registry mobile app |
