Old 05-21-2023   #1
efnfast
Default Noisy car leaving MR9
Car started making noise at MR9 (1,000 miles from home).
First thought it was a wheel bearing, then turned into more of a crunching noise. I suspect a clutch issue.
Not too long ago I installed a Ram clutch, flywheel and hydraulic throw out bearing. It gave me a huge amount of trouble (but that's another story). I've been leaking a little clutch fluid. This morning I found a big puddle under the car and found the clutch reservoir almost empty.
I'm going to start with wheel bearings because they are 33 years old and have 100,000 miles on them.
Looking for recommendations for bearings, heard bad stories about Timken.
efnfast is online now   Reply With Quote
Old 05-21-2023   #2
Young1
Young1's Avatar
Default Re: Noisy car leaving MR9
Rock Auto
AC DELCO Gold
Front and rear.
Steve Young
Second Owner
SOLD
SOLD
Old 05-22-2023   #3
Matt B
Matt B's Avatar
Good luck with the clutch!
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 05-27-2023   #4
efnfast
Front and rear wheel bearings on the way.
Do we have recommendations for half shaft u joints?
Old 05-27-2023   #5
Jagdpanzer
Jagdpanzer's Avatar
c4 corvette kit from Denny's Driveshaft
https://www.dennysdriveshaft.com/p42...0x_4_3_70.html
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-28-2023   #6
Make sure the u-joints are the kind that will not ?weld? themselves to the shafts duento dissimilar metals.
Old 05-28-2023   #7
efnfast
Duh, I have a good drive shaft guy local. I'll bring them to him and have him install the best he can.
Thanks for the input.
