Old 02-16-2023   #1
viper107
viper107's Avatar
Default 91 to 96 drivers door molding
anybody have one for sale?
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5
viper107 is offline   Reply With Quote
Old 02-21-2023   #2
z proud
z proud's Avatar
Default Re: 91 to 96 drivers door molding
I have a new black one ,,, it?s the door side molding
z proud is offline   Reply With Quote
Old 02-21-2023   #3
viper107
viper107's Avatar
Yes, that's what I need
Old 02-24-2023   #4
These are the same for all C4s 91-96.
Old 02-24-2023   #5
viper107
viper107's Avatar
i need one if anybody has one to sell
Old 02-24-2023   #6
Jagdpanzer
Jagdpanzer's Avatar
In the past I've reproduced these out of urethane resin from molds I made made from the original moldings.
Plan to do another batch soon. They run $50 for one, $80 for the pair plus shipping. You will have to take care of the painting.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-24-2023   #7
Jagdpanzer
Jagdpanzer's Avatar
The ZR-1 moldings are unique. Base C4 moldings are a bit longer and have a different wheel well contour.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-24-2023   #8
viper107
viper107's Avatar
it appears that mine has 2 10mm nuts at each end and then clips in the center,and special way to remove the molding? from the door
Old 02-24-2023   #9
Jagdpanzer
Jagdpanzer's Avatar
To gain access remove a few screws that attach forward edge of the rear wheel liner. Then you can reach the two 10 mm nuts that retain the molding clips. On my reproductions the 6 mm studs are casted in the molded piece and the clips are not required. Much stronger than the OEM piece.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-01-2023   #10
Is this molding for the door or the dogleg piece? I do know for a fact the door molding is the same,I've replaced one with a standard part. A word of caution to anybody looking to remove this molding from a 91, on #634 my car the molding is bolted the entire length of the trim,I destroyed one piece thinking it had snaps in the middle. To remove this the entire door has to come apart,window removed everything. It would be interesting to know when GM went with snaps in the middle. No keep in mind the trim is the same,the part of the trim that holds the studs,snaps is the same. The difference is one is stud insert and the other is a snap insert, these inserts are removable.
