01-30-2023 | #1 |
Dymags in 17x11
Hey, I'm looking at an 88 vert that has Dymags in ZR-1 sizes, were there any 17x11 Dymags with an offset that isn't correct for a 90 ZR-1? I don't want to fly out to buy this car for the wheels then get home to them being the wrong offset if the seller doesn't know the specs
01-30-2023 | #2 |
Re: Dymags in 17x11
A concentric spacer and longer studs are required for proper fitment.
I am not aware of multiple offsets. Marty |
01-30-2023 | #3 |
Re: Dymags in 17x11
Interesting, so the 11" Dymags are offset for the base cars?
01-30-2023 | #4 |
Re: Dymags in 17x11
Challenge Style 17x11 Dymags have the correct offset for a 90 ZR-1. The 17x11s in the later style wheels is 56mm... you need a spacer. 1988 has a 56mm offset
01-30-2023 | #5 | |
Re: Dymags in 17x11
What's the best way to tell visually? They do appear to stick out a little on the rear but it's hard to tell from the pics. |
01-31-2023 | #6 |
Re: Dymags in 17x11
Those are gen 1 challenge Dymags.
Disregard my answer as it was for Gen II wheels. Marty |
02-01-2023 | #7 |
Re: Dymags in 17x11
The tires on the rear look to be too wide for the wheel.
02-01-2023 | #8 |
Re: Dymags in 17x11
Hard to tell from the pics, but that's a good point, I hadn't considered someone would be dumb enough to mount 315s on a 9.5" wheel.
02-01-2023 | #9 |
Re: Dymags in 17x11
Its a 9.5, you can fit a 315 on those with no issues
