01-24-2023 | #1 |
Heater Core Repair or Replace?
Hey guys,
I recently discovered the heater core on my 1990 Zr1 was leaking. I just got it out and now I am trying to decide whether to replace it or have someone repair it. The aluminum replacement I bought looks on the cheap side and the pipes will need to be bent to make it work. I really don't want to ever have to do this job again. Is there a high quality replacement out there? Has anyone had success repairing the original heater core? |
01-24-2023 | #2 |
Re: Heater Core Repair or Replace?
Replace only. I would not try mending a 33 year old Heater core. While you are there you might want to replace the blend door actuator as it's a bear of a project to get in there
01-24-2023 | #3 | |
Post 135 - Replacing the Heater Core and Heater Hose Connection
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-24-2023 at 05:33 PM. |
01-24-2023 | #4 |
Thanks for the advice guys, I am just going to return the aluminum heater core and purchase the more expensive copper one from Zip corvette. Hopefully the fitment is better. Also, thanks for the great write up on how to remove the heater core Dynomite, it definitely saved me some time without having to remove the dash!
01-25-2023 | #5 | |
01-25-2023 | #6 | |
Cliff, Since you have several years of Zs, have you needed to do the 95 and will it be any different if not removing the dash? I was going the cheater route this weekend and doing a bypass. I thought eventually I would repair when retired as I just dread this more than pulling the motor and installing new cams. Thank you. If I were still in Hawaii I would just bypass and forget it, but it would be nice to have heat here in Japan.
01-25-2023 | #7 | |
01-25-2023 | #8 | |
I am assuming the 95' would be very similar.....except the CDM on 1995 is behind passenger seat I did pull the passenger seat before pulling the heater core on a 1990 ZR-1
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-25-2023 at 11:13 AM. |
01-25-2023 | #9 |
Hey Cliff,
I have yet to read your write up on removing the heatercore but when I did a 92 Wazoo car, only thing I can think of to avoid pulling the dash was cutting the heater core inlet and outlet and splicing the inlet and outlet to a new heater core. I ended up removing the dash and the whole thing took about 8 hours. At the end I was left with a plastic tube about the size of my thumb and three 7mm screws. I think the plastic tube probably was a connection to side window defroster vent on the edge of the dashboard. Having replaced the heatercore once, I have been religious about replacing the coolant every two years. |
01-25-2023 | #10 | |
