11-30-2022 | #1 |
starter voltage
Question
I was checking the voltage at the purple wire while cranking and noticed that the voltage was 8 volts while cranking engine. With volt meter on battery reads 12.6 volts at rest. Then while cranking it read 9.5 volts. Is this normal or do I have a problem. Thanks John 1990 white/black #2546 one of a few 4l8OE eq ZR-1's 147,xxx miles |
12-05-2022 | #2 |
Re: starter voltage
That is "a bit" low. Two things come to mind:
1) battery is tired OR needs a good de-sulfate charging cycle and then check voltage while cranking. It should be closer to 10.1V (Marc Hiabeck can be more specific. IIRC, the ECM gets "iffy" if the voltage drops below 10V). 2) corrosion of the battery terminals. For sure if you feel heat on the terminals when cranking, YOU HAVE CORROSION that needs to be cleaned! Same goes for the connection to the frame (negative cable). Be sure all connections are clean (and I use dielectric grease on the batter terminals to stave off corrosion. Or, there is battery terminal spray-on protective coating - avail @ most auto parts stores. (Also dielectric grease is usually available there too. Comes in handy for wire harness connections to keep them from oxidizing AFTER they are first shined up!)
12-06-2022 | #3 |
Re: starter voltage
Dielectric grease is an insulator, if you want a conductive grease, use No-Ox-Id. Both are water/moisture barriers but act differently. You can coat the terminals and connections with a small amount of dielectric grease (silicone) to try and insulate them from water and stave off corrosion, just like you can use plain vasoline or any other grease, but if you coat the terminals and connectors themselves with enough of it, you can actually prevent your car from starting because of all the insulation you are applying between them there.
12-06-2022 | #4 |
Re: starter voltage
Those are some good points to check. I'm in the middle of some upgrades to
my new address (Home) and get distracted by the contractors. So the car sits inside the garage where i can work on it when I have time. I will find out what's going on sooner or later and report back. Thanks John |
12-11-2022 | #5 | |
Re: starter voltage
Although (theoretically I suppose) a conductive grease may be better, it doesn't appear to make a practical difference in the specific application (battery terminals). Furthermore, if one accidentally (or otherwise) applied a conductive grease to a multi-pin connector, the possibility of shorting between the pins would be a real concern. A whole chapter could be devoted to automotive batteries - and the reasons for them to fail - specifically. But, to cut to the chase, a LOAD TESTER is an inexpensive tool to have to quickly sort out "what is what" in an automotive battery. Once a car battery is fully charged, one can know in 10 seconds if the battery is "up to snuff". (if NOT up to snuff, sulfate and other things come into play - food for another topic). And, as far as connector oxidation and other crud goes, an electronic connector solvent/cleaner goes a long way to refurbishing "iffy" connectors. Just sayin!
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 12-15-2022 at 05:28 PM. |
01-10-2023 | #6 |
Re: starter voltage
OK no update as the home improvements have taken over the garage and the
car sits under an outdoor cover on the inside of garage (no room to work on it. Will get back to working when the dust settles. John |
01-30-2023 | #7 |
Re: starter voltage
Final update,
This past weekend (Jan 28-29) construction slowed down allowing me to work on the starter (slow crank) without being interrupted. Once I got to the starter I did some voltage measurements. Starter ground circuit - voltage 0.23 volts normal reading 0.2 to 0.6 v0lts. Next circuit starter power circuit - 0.05 volts normal reading 0.2 to 0.6 volts. when I tried the next reading sparks came out of the starter. So in my mind (drag racer) Oops their is my problem the starter was going bad very slowly. Local auto parts store (O'Reilly's) was able to get a NOS Delco starter. Installed starter put everything back together . now cranks like it should the voltage at the starter solenoid now reads 9.9 volts while cranking with Battery voltage reading showed 12.7 volts before cranking. thanks for the help that made me think. John 1990 white/black $ 2546 one of a few 4l8OEeq ZR-1's |
