Old 11-10-2022   #1
Jetjock
Jetjock's Avatar
Default Code 44
No sooner than I fix the Code 43 than I get another code. This time a Code 44. I pulled it up and it's the left O2 sensor. I had this before on another car and it was relatively simple to fix by running the engine up and it cleared the code. I plan to jack it up and take a look to see if there are any wiring problems under there. I did move the wires around to put in the knock sensor and I might have done something at that time but the service engine soon light didn't come on for a long time while driving it. The car does have over 100,000 miles on it so it's not surprising that stuff starts to fail but it never came on before. Any thoughts?
Roy
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Jetjock is offline   Reply With Quote
Old 11-10-2022   #2
Mikey
Default Re: Code 44
100K miles on an O2 sensor it?s probably just time to replace it. They tend to foul around that time.
Mikey is offline   Reply With Quote
Old 11-10-2022   #3
Default Re: Code 44
Not a bad idea to change O2s with plug change.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-11-2022   #4
Jetjock
Jetjock's Avatar
Default Re: Code 44
As far as I can tell, GM discontinued the O2 sensor for the LT5. What are everyone using to replace sensor? What is the length of the cable?
Roy
Roy L. Carman
NCM Lifetime #1468
Old 11-11-2022   #5
Default Re: Code 44
I recently picked up a couple of AC Delco off ebay. RA has sensors just not Delco. But I would not use Bosch.
Old 11-11-2022   #6
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Code 44
I've been having good results with NTK O2 sensors
https://www.ebay.com/itm/12134224459...mis&media=COPY
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
