Old 05-30-2007   #1
Peaven
Peaven's Avatar
Default Found the cause of the clicking noise...
...from the rear of my Z and it wasn't the u-joints, spindle washer, or lack of lube on the spindle. The leaf spring end bushings were toast...looked ok on the outside, but there was a whole lotta nothing in the center as the bolt was nice and shiny from flopping around on the leaf spring and knuckle eyelet....poly bushings are going in this time. The u-joints look ok but i'm going to replace `em anyway since I've got it apart.
Peaven is offline   Reply With Quote
Old 05-30-2007   #2
Jeffvette
Default Re: Found the cause of the clicking noise...
Good deal Steve. Be sure to check the rest of your bushings.
Old 05-30-2007   #3
Peaven
Peaven's Avatar
Thanks for your help Jeff...most of the other bushings look pretty good...but as I found out you can't always tell just by looking. I'll be checking things out a little closer tonight as I wipe some of the road grime off of everything and clean it up back there.
