Old 08-29-2022   #1
Young1
Young1's Avatar
Default Prototype Piston Award Signatures?
I purchased this at the Carlisle auction.
What is the significance of the the steel band molded into the skirt?
Ray Cline? Chris Allen? What were these mens tasks in development?
Rick Kuli?
Gary Van Duster?
Steve Young
Second Owner
SOLD
SOLD
Old 08-29-2022   #2
grahambehan
Default Re: Prototype Piston Award Signatures?
Steel inserts to help control thermal expansion.
Gary Cline, Chris Allen, Greg Vandeventer and Rick Kirk
Graham
grahambehan is offline   Reply With Quote
Old 08-30-2022   #3
Matt B
Matt B's Avatar
Steve, I can't contribute to your questions but let me say that this is DAMN cool piece!
Congratulations!
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 08-30-2022   #4
staminqia
staminqia's Avatar
Steve a cool piece!
I see you made it back to Florida! great to meet you in person.
Anthony
staminqia is offline   Reply With Quote
Old 08-30-2022   #5
A great find Steve! And thank you Graham, for your explanation. I have a piston from a '93 engine and I had honestly never noticed the little steel inserts until today after Steve mentioned it and I noticed just a bit of rust that has formed on the steel (after sitting on my deck for probably 20 years). A great bit of ZR-1 trivia. But I am curious: do other aluminum pistons commonly have such steel strips to adress thermal expansion or is it just the LT5s? --Bob
Old 08-30-2022   #6
grahambehan
Thanks for showing pictures of the later piston Bob.
If you compare the earlier piston pics, you will see the subtle change in the piston casting to better support the expansion insert towards the pin boss, since the early ones used to break off at that point. Also the piston change to add an accumulator groove.
Cool stuff.
Graham
Old 08-30-2022   #7
tf95ZR1
tf95ZR1's Avatar
I never knew or noticed before either.
My simple mind is trying to figure out how they'd help with thermal expansion.
Improved heat dissipation?
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 08-30-2022   #8
Young1
Young1's Avatar
Per Grahm, steel inserts to control thermal expansion. This means they could have a tighter tolerance of piston skirt to cylinder wall to control slap and wear?
Steve Young
Second Owner
SOLD
SOLD
Old 08-31-2022   #9
Cool stuff.
Graham
Hmmm...they "used to break off"--scary. And yes this is "cool stuff", to mechanical geeks like me. But I must admit I had to look up what a pin boss was. Here are a couple of cutaways for other would-be piston nerds. Now that I look at the newer vs older piston pictures, I do see that the pin bosses seem to be a little beefier in the newer pistons. Still curious--do you know if other aluminum piston also utilize the steel inserts or is it just an LT5 thing? --Bob
Old 08-31-2022   #10
grahambehan
Bob, Yes on cast pistons.
Graham
