Old 08-15-2022   #1
Erik
Default Best Place for Negative Battery Cable?
Seeing as how Jerrys doesn't stock the negative battery cable, where do you suggest I find one? Anything unique about them?
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 08-15-2022   #2
secondchance
Default Re: Best Place for Negative Battery Cable?
Any reason you are wanting to replacie battery negative cable?
Old 08-15-2022   #3
Erik
Just a few thoughts. One, the head of the bolt that goes into the battery is becoming rounded. Two, I've had some nasty failure of old negative cables in cars years gone by. Three, as I'm starting to figure out the electrical glitch affecting the alternator, a good negative cable, with a solid ground, seems a safe bet.
Is there a reason I shouldn't be?
1990 ZR-1 # 996
Old 08-15-2022   #4
JG95ZR1
JG95ZR1's Avatar
The bolt can be corrected with a set of dorman 60307 terminals. If the cable does not look bad and terminal do not show corrosion it?s probably good.🤷🏻
JG95ZR1 is offline   Reply With Quote
Old 08-16-2022   #5
secondchance
I agree. If the cable passes visual inspection, just replace the bolt.
Old 08-16-2022   #6
mlipmd
Walmart, $2.37 for 2 terminals, or get a bolt from the hardware store and maybe a washer or two if the bolt is too long. Easy fix and no need for a new cable.
mlipmd is offline   Reply With Quote
Old 08-16-2022   #7
secondchance
https://www.topflightautomotive.com/...terminal-bolt/
Old 08-17-2022   #8
mlipmd
Sorry, made a mistake, it's $2.27 for two.
https://www.walmart.com/ip/EverStart...7?athbdg=L1600
Unless you feel like spending $3.99 for one.
Old 08-19-2022   #9
Young1
Young1's Avatar
The side post battery bolt are on the shelf at any auto parts store. Buy a 5/16 battery wrench while there.
Steve Young
Second Owner
SOLD
SOLD
Old 08-20-2022   #10
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Yes, to all of the above posters.
Bolts and WRENCH!
We typically replace the bolts with ones that have a terminal and bolt on them enabling a permanent battery tender connection with the wire hanging through the fender gill openings.
This simplifies battery charge maintenance.
Marty
