Old 08-14-2022   #1
jrd1990zr1
jrd1990zr1's Avatar
Default Brake petal goes low intermittently
Took my 1990 out today, was running great. After about a half hour of driving when coming to a light to stop, petal went way down before the brakes engaged. Brake light on for a short time. Petal felt strange. Brakes seemed to work after that but then it happened again after about 6 or so more stops. Fluid in the two reservoirs are where they should be.
Any thoughts on what may be causing this?
Thanks in advance.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 08-15-2022   #2
Default Re: Brake petal goes low intermittently
Thanks in advance.
Maybe a Compromised brake booster? Open the hood. With the car running have somebody push the brake a couple of times and hear if you have any vacuum noise Coming from the booster area
Old 08-15-2022   #3
Young1
Young1's Avatar
Install a new master cylinder immediately. Do not drive it anymore.
Steve Young
Second Owner
SOLD
SOLD
Old 08-15-2022   #4
jrd1990zr1
jrd1990zr1's Avatar
Two questions. Why do you think it is the MC rather than the booster? Any idea where you can find a new MC or have this one rebuilt? Rockauto are mostly out of stock.
Old 08-15-2022   #5
jrd1990zr1
jrd1990zr1's Avatar
GC, So if I hear a vacuum noise does that mean the diaphragm is shot in the brake booster? If I don't hear a vacuum noise is it possible it is a bad MC? Do you know of anyone who can rebuild a C4 MC or booster, or a place to buy one?
Thanks.
Old 08-15-2022   #6
Thanks.
Normally yes and yes
I hope it's the master cylinder as those are easier to find and the 4 bolt vacuum boosters are a bear to find.
Old 08-17-2022   #7
Young1
Young1's Avatar
Booster is an assist and has nothing to do with the height of the pedal. The pedal went down because fluid escaped past the pistons in the master cylinder. That causes the light to come on. It happened to me once, right before my favorite twisties. O Reillys has a master cylinder for you for under $150.00. Brakes are life and death and thus my abruptness brother.
Steve Young
Second Owner
SOLD
SOLD
Old 08-18-2022   #8
jrd1990zr1
jrd1990zr1's Avatar
Steve, I was able to confirm the booster is functioning. Are you aware of a way to 100% verify that it is the MC. I am not questioning your expertise, I don't want to pull it off and have to rebleed the entire system if there is any possibility it could be something else. Looks like the replacement shouldn't be too difficult, 1 electrical connection, two hydraulic lines and a couple bolts. Any other advice would be appreciated. BTW O'Reillys in upstate NY wants $170.00 for the MC. Thanks, John
Old 08-18-2022   #9
conesare2seconds
Tricky part of the MC replacement is the C-clip from the pedal to the rod. You?re upside down with your head in the footwell and it?s dark even with a good light. Be patient, it will work.
Old 08-18-2022   #10
If the booster is good to go then the master cylinder is the culprit. Looks like you are in good hands advise wise. GC
