Old 08-11-2022   #1
zpyroro
Default drainage hole info
Anyone know where I can access the info on how to open up the drainage hole under my he plenum? There was a GM service bulletin years ago about this. Thanks
zpyroro is offline   Reply With Quote
Old 08-11-2022   #2
Young1
Young1's Avatar
Default Re: drainage hole info
There is a bulletin to drill a 3/8 hole in the rear of the block in The Valley of the plenum. Why not use a drill bit, a stiff wire and an air blower to clear the oem tube? You have to pull the starter to do either anyway.
Steve Young
Second Owner
SOLD
SOLD
