Old 08-08-2022   #1
lfalzarano
Angry 90Z won't start
The new battery tested 700 CCA. The car has been sitting for a month on a charger. With the clutch to the floor, I turn the key and the dash lights up, and then turn the key to start and the portion of the dash ahead of the steering wheel dims a little. The starter does not crank.
I'm sitting at the bottom of my driveway so there is no way to push start it. It is reminiscent of the usual DNS threads after driving and parking. But it hasn't been driven nor was the engine hot.
Suggestions to where to start in the FSM or posts?
Old 08-08-2022   #2
Young1
Young1's Avatar
Default Re: 90Z won't start
Two questions for you
When you turn key to crank does the voltage lower on the voltmeter?
How many miles on the car?
Steve Young
Second Owner
SOLD
SOLD
Old 08-09-2022   #3
The solenoid and the solenoid contacts need cleaning.......
Often if you keep trying with the key start a "good enough" solenoid contact enough for starter current can be made.....you may then be OK for a while or the next day have a repeat until you refurbish the solenoid.
This does happen more often with a starter/solenoid that has not been used for a while.
Push the car out of your driveway and have a couple of guys then push the car forward and you pop the clutch in second gear with key on.
Old 08-09-2022   #4
lfalzarano
No the voltmeter never moved. As to your second question, the mileage is 86K.
Old 08-09-2022   #5
lfalzarano
It only sat for a month. But I need to get some younger friend to assist in a push start. My problem is the car is sitting at the bottom of the driveway hill. There is about 35 feet of level driveway. We might be able to have it kick over before I?m back in the garage[emoji1317]
Thanks for the suggestion. I will give it a go.
Old 08-09-2022   #6
KPW
KPW's Avatar
Lots of detail to be found here:
http://www.zr1specialist.com/HAT%20W...20Problems.pdf
If the voltmeter isn't dropping, it might be worth shorting the clutch safety switch (have a look at the last paragraph in the PDF above).
For what it's worth, I fought the "no start" intermittently for a while, including shining up the solenoid contacts. Finally bit the bullet and did the DNS Relay Mod - completely worth it for the peace of mind.
http://www.zr1.net/forum/showthread.php?p=88156
1991 ZR-1 #1438 Black/Black & Red
KPW is offline   Reply With Quote
Old 08-09-2022   #7
lfalzarano
I went through Marc?s guidance and it all points to under the dash as the source.
I?ve tried other suggestions except the push starting it. I called AAA to flatbed it to my dealer in Cary, NC. They replaced the clutch pedal position switch less than 6 months ago. It was a MidAmerican Motorworks part, but I don?t know who made it.
Old 08-09-2022   #8
tiegsd
tiegsd's Avatar
Just had no start issue with my 90, it was the clutch switch. Easy enough to test and bypass to get the car to start. Made up a jumper for the connector under the driver's side hush panel till I can get a replacement. If not that, things get a little harder, starter contacts are known issue per previous posts. VATS is another potential trouble spot if yours hasn't been bypassed (mine is).
1990 Black/Black ZR-1 #1155
1993 White/Red coupe (Regrettably sold)
tiegsd is offline   Reply With Quote
Old 08-10-2022   #9
Matt B
Matt B's Avatar
I can only recommend the relay mod. A power relay and proper wires will deliver way more power to the starter.
I had a DNS right on the first day she ran in my yard. Did the mod and it never came back. AND this solution maintains the clutch safety switch which is a useful feature.
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 08-10-2022   #10
Young1
Young1's Avatar
I agree with tiegsd on the clutch switch. Easy to bipass with two spade connectors. Check that first. Then second I agree with dynamite. plenum pull to shine up the copper contacts. This will happen every 35 to 40 K miles. So far I have cleaned contacts several times but never replaced a clutch switch.
Steve Young
Second Owner
SOLD
SOLD
Tags
does not start, won't crank
