07-25-2022 | #1 |
Coolant Bypass from Marc Haibeck
Does anyone have a picture of the coolant bypass installed that Marc sells? I bought one and I'm kinda of a visual type. I want to see what it's supposed to look like. Thanks.
Roy
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 ZR-1 Net Registry Board Secretary |
07-26-2022 | #2 |
Re: Coolant Bypass from Marc Haibeck
This should help...
07-26-2022 | #3 |
Cool. This helps a lot. Gorgeous motor! Thanks. Roy
07-26-2022 | #4 |
I presume you saw the picture of the tube itself on Marc's website, but if not here it is. --Bob
07-26-2022 | #5 |
Difficult to get a good picture installed since most of it is hidden, but hopefully these help a bit.
1991 ZR-1 Dark Red Metallic/Black #1648 Stainless Works headers, OBX cat-back, Haibeck chip, Haibeck 170 degree thermostat, throttle body coolant bypass, led headlights & fog lights, Etoile 455 3-piece wheels. 1973 Stingray Black/Black #421. ZZ4 with Holley Sniper EFI, Tremec TKO-600 5 speed, 3-row aluminum radiator, 18? Foose legend wheels, + lots more. |
07-26-2022 | #6 |
It gets tight in the area of the TPS. Make sure your alternator positive is covered. I had no luck installing it with the plenum on. It?s a good piece. Go for it.
08-22-2022 | #7 | |
OK. I have the plenum loose but the question is this: Does the long end go on the right side of the engine because that's an interesting angle and a long hose to go in. Do you trim the rubber hose on the right side of the engine? Kinda wish I could see the installation process. That would answer a lot of questions. Roy
08-23-2022 | #8 |
Marc Haibeck installed the one I pictured above so I'm unsure. I did my own install of this mod on my old ZR-1 over 20yrs ago long before that custom metal tube was offered. I cannot remember exactly how I did it, but I believe I just bought one long rubber hose and ran it from one end to the other underneath the plenum.
Jay |
08-23-2022 | #9 | |
09-02-2022 | #10 |
Marc did a 510 package and he cleaned up the look .
91 Turquoise Metallic Haibeck 525 #0134 |
