Old 07-24-2022   #1
Johnny5
Default Cruise control shutting off when using blinker
So the cruise control works but when i turn the blinker on the cruise control shuts off. I recently had no brake lights working and replaced the brake light switch. I also had a keyless entry installed: simple lock and unlock from Avital. Anyone experience this or know what it could be?
I also installed LED headlights with the
Proper resistor and LED fogs.
Any feeback would be appreciated
Johnny5 is offline   Reply With Quote
Old 07-24-2022   #2
Mikey
Default Re: Cruise control shutting off when using blinker
When you turn the blinker on are all the exterior lights functioning as expected? Seems the turn signal and brake light circuits may be cross wired.
Mikey is offline   Reply With Quote
Old 07-25-2022   #3
I would say there is a short in the stalk.
Old 08-03-2022   #4
I think there is a problem with the wiring traveling down the column for the cruise. Have you done anything on the column?
