![]() Join Date: May 2022
Wanted original OEM wiper blades ...My 93 ZR1 has 2 mismatched wiper blades and neither of them are original.
Does anyone have an original correct set they could part with ? $ Thanks Bob Last edited by bob@tradeshowconsulting.c; 07-09-2022 at 06:53 AM. |
![]() Join Date: Feb 2010
Try Mirrock Corvette.
Gary 90-1572 ![]() |
![]() Join Date: May 2018
I contacted Trico and got a set 202 for my 91. I could not find the reply they sent advising the part numbers for c4 corvettes.
These fit perfectly, stop and park as designed. |
![]() Join Date: Apr 2007
Often wiper blades are intentionally mismatched, as in one is made shorter than stock, because the OEM ones would often bang together with a very loud scary noise. Mine even did this when they were adjusted correctly per the FSM. Shortening one resolved the issue. Until I bought a shorter one (for I think the driver's side) I really didn't want to use the wipers after the first few times. Afterwards they worked fine. But if you are looking for OEM wipers for NCRS purposes, ignore this. --Bob
Yes..Thanks.. I am aware of the Trico and will use the rubber insert/blade. However, I really want the metal blades that are the factory original to the 1993 corvette. I just like to keep everything original. I wont drive it in the rain .so function is not as important as originality of OE parts.
Thanks |
